I will not comment on PianoSens specifically, but I appreciate the thoughtful dialogue. I not exactly sure I understand the objective either. Ultimately, if the objective is of this technology is to achieve perfect, solid tunings without relying on aural skills then we've got a problem. If we acknowledge that it is only an impressive tool to make that job a bit easier and faster, than we have plenty of room to adapt to different methods and all is good, IMO. The most fun part of tuning is shaping unisons and honing in intervals beyond what the computer is able to suggest.
Retired, St. Olaf College
Dennis Johnson, R.P.T.
Sent: 03-23-2024 13:50
Subject: First tuning experience using PianoSens
Fred, below is a link demonstrating how quick and easy it is to get to 0.1 cents in 10 seconds time per string. -- Steve
https://youtu.be/xXBUTAjbw_A
Steven Norsworthy
Cardiff By The Sea CA
(619) 964-0101
Sent: 03-23-2024 11:31
Paul,
I said "difficult to impossible." What you describe is convoluted and difficult. And do you really have assurance that your spot on pitch is stable, that every string tuned that way will last through the Prokofiev concerto?
I simply point out that the most efficient use of an ETD, for precision AND stability, is to use the display as I described: When you are at pitch, you manipulate the tuning pin sharp and flat without moving it in the block, using flex and twist. You observe the pitch going just sharp and just flat by equal amounts and then center the pin. (When there is significant friction, it becomes more complicated).
This can best be done by using the strobe-like display in the background of PianoScope (and PianoMeter and TuneLab). But that display will be reading flat of the freeze-frame. So the strobe becomes useless for precision if you are aiming for the freeze-frame pitch. Pretty counterproductive in my view.
Then there is the question of where the freeze-frame pitch should be read. Last November, when it was invented/promulgated, we were told one should tune to the pitch that was at a particular point in the decay, with specific defaults for different parts of the range (as Jason Kanter pointed out, those are set as defaults in PianoScope, and they are significantly sooner than 700 microseconds after attack). Now we are told that the actual freeze-frame pitch is not the pitch at that point in time, but rather an average of pitch from the attack to that moment, and the inventor now likes to use 700 microseconds in.
As far as I can tell, all of this is simply BS. It doesn't matter what point of the sound envelope you tune to as long as you are reasonably consistent. The difference in pitch during the decay is not large enough to be significant. Nobody cares. A piano can be between 439.5 and 440.5 Hz and nobody will notice.
What they _will_ notice is unisons and stability. So however you tune, that is where your main focus should be. And tuning to match a freeze-frame makes it difficult to achieve stability, because you can't use the most precise and reliable feature of the ETD display.
www.artoftuning.com
"One's real life is so often the life that one does not lead" (Oscar Wilde)
Sent: 3/22/2024 7:35:00 PM
Subject: RE: First tuning experience using PianoSens
Hi Fred:
Not to beat the horse, but I have been able to achieve what you are claiming is not possible. I use this system daily. I use both the red line and the freeze line. You have to anticipate and closely watch all of the indicators so that when you give a final test blow that the freeze line is as close to the target as possible. Your test blows have to be as consistent as possible, as opposed to a harder blow meant to settle the string. If you don't stop the string vibration before the test blow, the grey line may not be accurate. My technique is to watch the red line go just sharp of the freeze line, and see it settle back to zero in a very short time. Not a few seconds. The time "window" for the red line is much shorter than the grey line, and is actually less accurate. The red line is not continuous, but it is a repeating calculation that appears to be continuous. Just like frames on a movie projector appear continuous. So, the red line IS useful to get close, but the most accurate calculation is the grey line.
In Settings on the Freeze I use 750ms from C1 up to C3. On C4 to C6 I use 350ms, on C7 I use 300ms, and 150ms on C8. That way I try to get the measurement during the most powerful attack time. You can reset the freeze more quickly with a shorter freeze time.
I also like to observe the "strobe" bars in the background to see what is the tendency of the overall pitch. If I see the strobe going strongly left or right, even if the grey line says zero, I'll question that. A little movement either way is ok, mostly to the flat side because that's normal.
I find that I can get the red line very close to zero on a soft blow, and the grey line will be very close also. I wish I could observe what you're doing.
As far as unisons, like I said before, I can get them very clean using the freeze line, and they do stay there. All of this discussion of course depends upon the skill level, not that I'm questioning yours. It takes a little extra time to isolate the individual strings, so that's there too. There's definitely a learning curve in this, and I had to spend extra time mastering this process. I had to up my skills because I could see there was room to improve. It takes some getting used to. I do wish I had some kind of pounder that I could press a button that would give a perfectly consistent blow every time. Maybe Pianodisc or QRS could come up with some sort of handheld plunger. That would certainly help with getting the most accurate results.
Whether you use the decay phase to tune unisons, or using the freeze during the first second, as long as they are clean I don't see a problem. You just have to choose which method you're comfortable with. Whatever works.
Anyway, all of this is new to the tuning community, and you can choose to implement whichever feature you find useful. Or not. Whether to tune to the decay phase is up to you, but using new measurement instruments like Pianoscope and Pianosens can show errors in doing that. Does it matter? Maybe it doesn't to some, but I'm not alone to think that having the most accurate method is better. The other aspects of tuning still apply, such as proper pin setting, etc., so using this system isn't going to negate proper technique.
I appreciate your honest assessment, and your time to post it.
Paul
Sent: 03-22-2024 18:06
In terms of practical and precise tuning, the pitch difference between prompt tone and two seconds later is irrelevant. We don't really care about that level of pitch difference for the note itself. What we care about is the resolution of the unison, which can best be gauged over the course of a couple seconds, at least for bass through the mid range. Gauged aurally. Does the unison hold its quality?
And the way we get there using an ETD, watching a display while manipulating the tuning hammer, is by having the display mirror the effect of the manipulation of the pin in real time. This, of course, refers to establishing reliable stability. We don't care about the ability to create a perfect, temporary unison. That is useless. It has to last, to hold up to time and heavy playing. (Though we have no control over the effects of environmental conditions).
Stability is best gauged, using an ETD, by discovering what happens to pitch in real time when twist/flexing the pin upwards and downwards. A freeze frame is useless for this process.
www.artoftuning.com
"A mind is not a vessel to be filled, but a fire to be kindled." Plutarch
Sent: 3/22/2024 4:24:00 PM
An update to Fred.. of course even a medium blow force will integrate as a sharp note relative to 2 seconds later. The power is in the first second. That is what we tune to acoustically and musically.
Steve
Steven Norsworthy
(619) 964-0101
Sent: 03-22-2024 16:15
Any blow force below a certain level will 'not' deviate the freeze line biow to blow. That is what Paul and I and others see. You should see the same. It has to do with the nature of the nonlinearity of spring physics. The hard blows are not the way to tune.
Steve
Steven Norsworthy
(619) 964-0101
Sent: 03-22-2024 15:55
Where is the "medium" blow? And how do we control the force of the freeze-blow to anything like the degree of accuracy we're seeking? Because the slight difference in the blow will affect the precision of the freeze. My robot could do it with repeated accuracy, but not I.
| || ||| || ||| || ||| || jk ||| || ||| || ||| || |||
jason's cell 425 830 1561
Sent: 3/22/2024 3:09:00 PM
Fred and Jason and Paul,
The 'blows' should be 'medium' and not 'hard' for getting the freeze line to the right number. I 'invented' the 'concept', disclosed it to Frank at Pianoscope, and Frank 'implemented' and did a good job, kudos to Frank. As Frank and I were 'experimenting' with it during the beta phase, we indeed recommended default settings faster for higher notes and slower for lower notes. That works well, but I like putting all the settings at 700ms because where there are false beats, there is more time to resolve them at the slower setting of 700ms.
Again, 'meduim' blows.
I had 5 very experienced pro tuners at my house yesterday for a demonstration. I got the unisons at zero cents just and they all told me that they have 'never' heard such a perfect unison. They all had collectively experience with all the commercial tools and apps.
I can take a call at 619-964-0101.
Steve
Steven Norsworthy
(619) 964-0101
Sent: 03-22-2024 14:33
About the freeze line. There's a setting to change it. You can specify how many milliseconds it will average to set the freeze, and that number can be set for C0, C1, each C up to C8. On my iPad Pianoscope app, C0 is currently set to 500 ms, C1 to 400 ms, C2 through C8 all 300 ms. Nothing is set to 700. (I have not changed these settings.)
What difference would it make to change the milliseconds? I don't know.
Test blows produce a sharper freeze line than normal tuning blows, so whom do you believe? Its erratic behavior makes the freeze line a nuisance distraction from the ear.
Personally, at the moment, I ignore the freeze line. Instead I stop the strobe blocks. When the blocks lie still, I'm good. One of the pleasures of this is that I can gaze at something pleasant and keep the strobe blocks in my peripheral vision. Try it - it's profoundly different from focusing on a small screen, and promotes the practice of listening with your whole body.
My pianosens is in the mail. I'll be tuning my own Kohler & Campbell studio in a few days, if I can locate the piano under the books and papers and boxes and bags.
Jason Kanter
Lynnwood WA
(425) 830-1561
Sent: 03-22-2024 11:11
It is very helpful to learn that the freeze frame is an average of the first 700 milliseconds (2/3 of a second). That explains a lot. IOW, it includes the widest excursion of the string, the very sharpest point in the trajectory of pitch. Hence, the freeze point is always sharp of what the display is reading at the moment it appears, and in order to match the freeze point you have to "tune so the display is reading sharp" (the strobe emulation rectangles must be moving in the sharp direction). This is difficult to impossible to do with any accuracy, a very frustrating setup.
Far better to freeze on an average of 300 - 700 milliseconds in. Then you will have a target you can come close to matching during your real-time manipulation of the tuning pin using feedback from the display.
But frankly I don't see the utility in having a frozen freeze point. From a pragmatic point of view, actually manipulating the tuning pin using feedback from the display, it is better to sacrifice extreme accuracy of pitch in exchange for clarity of what you are doing in real time. The results speak for themselves in crystal clear unisons.
As for whether the pitch should theoretically (according to some intellectual/scientific model) be 0.2¢ or so sharp of the result you get, who cares?
"Believe those who seek the truth; doubt those who find it." Gide
Sent: 3/21/2024 10:39:00 PM
No one out there seems to understand the Freeze frame concept. It's up to the inventor to explain.
No, the Freeze is not a snapshot, it is window of time from the hammer strike to about 700 milliseconds thereafter, where that 'average frequency' is measured over that duration of time window where the signal power is highest. There is no such thing as an instantaneous frequency measurement in zero time.
The real 'driving force' for the invention of the Freeze frame window is that the 'pitch' also decays as the amplitude decays. Can any human watch a continuous reading and remember were the pitch was consistently? No. The Freeze indicates that, and it is the ONLY consistent way that has ever been described or reported.
The piano decays in amplitude about 20 dB / sec in the mid range, and about 20 dB in 300 milliseconds in the upper register. Tune where the power is the highest, in the first second. The piano not only decays quickly but the human absolutely cannot perceive the pitch accurately in the first sec, nor can most any ETD, 'unless' it integrates it over that time using an FFT.
Steve
Steven Norsworthy
(619) 964-0101
Sent: 03-21-2024 14:41
Paul,
I have experimented with the freeze frame. I find it unreliable, since it will vary with the amplitude of the attack. I also find it doesn't meet my needs because it is a snapshot. Once it is shot, you have no further feedback with reference to it (which is what you want to reach "end goal pitch") until you play the note again, You are simply noting where it is and then moving in the direction indicated, relying on a moving and jumpy needle and a moving strobe emulation in the background - but if you use the strobe as your guide, you won't match the freeze frame when you are done.
I find that with those apps that have a "needle" (which varies from PianoScope's line to TuneLab's peak to PianoMeter's actual needle), the needle is good for the initial pitch move, but achieving accuracy and stability reliably depends on using the strobe (the moving gray rectangles).
RCT's composite display, where all elements are combined into one interface, is far more intuitive: spinner moves left and right to give rough tuning indications. As you approach the center target, it grows and spins slowly left or right. As you hone in it stops spinning and fills in, in stages.
Since all this movement is buffered (essentially averaging pitch over several microseconds), one can develop a connection between the eye and the hand on the tuning lever. Movements of the pin are reflected in real time for their effect on pitch. This is particularly important for achieving stability, as one can make minute movements of the pin (flex/twist) and see what their effect is, aiming for equal movement sharp and flat, settling in the middle.
In the other displays described above, one sees what the target is - which way to go and how far - but while one is making the final, most important moves to precise placement of pitch, it is guesswork followed by playing the note again to confirm (deciding between conflicting information between needle and strobe, and when to look). And the final refinement of precision/stability is also problematic, as the display doesn't "follow the tuning hammer."
Sent: 3/20/2024 11:52:00 PM
Hi Fred:
I have been using the Accutuner since I began tuning in 1988, so I know what you mean about the slower display. I can't imagine it being any jumpier.
As far as using Pianoscope, I started using it about a year ago, and I've seen it make improvements along the way, especially the Freeze concept. I wish all of the ETD's had this feature. Anyway, the Freeze line helps you make better decisions because it only measures during a short duration of time after the initial blow. The pitch is more accurately determined that way. As you know, the pitch is constantly changing as the decay period goes on. If you measure the pitch during the attack phase, in a limited time frame, you'll get a better reading. Since PIanoscope (and other ETD's that use multiple partials) require measuring them to calculate the pitch, if they fade away, they can't be used. So, the measurement needs to be done while the partials are sounding their loudest. Waiting seconds later, the pitch is falling and the partials are fading. All of the pitch information needed is in the first second of string vibration.
Here's the thing- this feature would not have been possible to create until recently because there wasn't enough processing power in our IOS devices to run it. It is entirely a new concept. Of course, we have always advised to "tune to the decay" except in the treble where we "tune to the attack". Well, obviously, there is not other option up there. But creating a "time window" where the pitch measurement is done, the reading is more consistent. That's why it was invented. The Freeze line appears after a specified time measured from the initial blow. You can set this time window from 100 miliiseconds to 999 (1sec). During this time, an average measurement is made, and then displays the pitch as a grey line. Play the note again to reset the grey Freeze line. Be sure to release the key so that the string stops vibrating for a half second so that the program knows you're resetting the Freeze. Otherwise it gets confused and gives a false reading. Very important point.
You can use the red line, and the "strobe" in the background, to get close to the pitch, but then use the grey Freeze line to land as close to zero as possible. If you're in the high treble, this is more tricky especially with false beats and such. Sometimes I'll watch the strobe in the background and try to get it to slow down and stop, or oscillate back and forth in one place. I look at all the indicators and decide ultimately with my ears where I want to leave it.
As far as unisons go, if I use the Freeze line, I can tune beatless unisons consistently. My tunings are much cleaner than before, and I can correct them later by simply isolating the strings and retuning them. Bad unisons stand out like a sore thumb when the rest are quiet. If you like smearing unisons, that's a choice too. There is a reason that all of the ETD's suggest using your ears to tune unisons, and that is because they don't have the necessary consistency to make them perfect. Of course, you can get them close, but by ear getting them closer than .4 cents is hit and miss. Adding the Freeze to Pianoscope makes it easier and more accurate, down to .1 cent. Doing this requires a little extra time and finesse, but the result is worth it, IMO.
Using the Freeze feature makes it much easier to tune than watching the red line jumping all over the place. I use them both while tuning, but the Freeze is where the pitch is most accurate.
I hope you'll give it another shot, and I hope I've explained things a little better.
Sent: 03-20-2024 20:39
I tuned this afternoon in a jazz venue where there is a gas furnace hung from the ceiling, with a very loud fan (it is turned off during the concerts). Typically I just stop tuning for the few minutes each heating cycle takes, but this time I plugged in PianoSens and had no problem continuing to do quality work.
IH readings used to calculate the tuning have zero affect on how the device displays a string, how jumpy it is. I found only few tiny discrepancies between the measurements of the two devices: when I had the pitch zeroed (full blush) on the Pianosens device, the other display drifted slightly sharp or flat on a few strings. This drift was in the 0.5¢ or smaller range, not significant IMO. What is important is the quality of the unison, so as long as the device is giving consistent readings, the unisons will turn out well.
I recall talking to Al Sanderson maybe 25 years ago, and he said some tuners wanted him to make the Accutuner more precise, react more quickly. He said that was easy to do, but it would make it much more difficult to tune with it. Better to smooth the curve, averaging the pitch over time.
I did a wee bit of experimentation with PianoScope and PianoSens this afternoon, again using iPad and iPhone in parallel. I found that the jumpiness of the "needle" (red line) was damped somewhat in the midrange, but still significantly jumpy, quite troublesome to do refined work. The high treble was damped quite a bit more, but still difficult to interpret.
I think Al Sanderson was right, and that Dean Reyburn refined those ideas to create an interface that allows one to "know where one is" and get instant feedback as the pin is manipulated, which makes achieving stability much more efficient. While other apps may be displaying the real moving pitch more accurately in real time, that doesn't necessarily help one do good work. In fact, it is a hindrance in my experience.
fssturm@comcast
"The cure for boredom is curiosity, and there is no cure for curiosity." Dorothy Parker
Sent: 3/20/2024 7:08:00 PM
Fred, make sure the IH is 'different' with the mic and sensor. It matters. Did you use separately acquired IH's?
Steve
Steven Norsworthy
(619) 964-0101
Sent: 03-20-2024 15:15
I had the opportunity this morning to tune a piano using my iPad and iPhone side by side, phone with PianoSens, iPad using its built-in mic. The results were as I described in my earlier post: moderate increase in resolution from PianoSens. The biggest gain was in the bottom octave (steadier display versus "flashy" display). There were a few strings where PianoSens gave a significant aid in tuning.
Concerning FFT (Fast Fourier Transform) vs Zero Crossing, I have no expertise. (I gather RCT uses Zero Crossing, while TuneLab/PianoScope/PianoMeter/Verituner use FFT - correct me if I am wrong). However, I do know that I find I can get significantly better aural results with less effort tuning with RCT versus TuneLab, PianoScope or PianoMeter. This opinion is based on listening. If FFT provides more precise real-time data, that doesn't necessarily mean that a display based on it will be a better visual source for the tuner.
I am VERY skeptical of the assertion that it takes two seconds to get 1 cent resolution (on 440Hz) using zero crossing, but I have zero interest in arguing the point.
I am interested in quality tuning. Twenty years of experience tuning with RCT (trying other options from time to time) including a large proportion of concert and recording work, has convinced me that my results are stellar (as do my own ears).
Sent: 3/20/2024 8:03:00 AM
And the sensor's total deafness to outside interference (as many of us including Fred) have noticed means that we can carry on our work in total defiance of even the most obnoxious and persistent noises going on around us. No more: "Quiet please!, I'm tuning the piano!"
I recall trying to tune on a tourist ship going out to the Isles of Shoals here out of Portsmouth years ago. The piano was right above the engine compartment (or at least it seemed like it). I thought I could accomplish it...forget it. I had to wait till the ship was docked (and it was NOT a planned trip). Those risks are now gone.
Sent: 03-20-2024 02:24
Fred, there is a very rational reason why older apps that go back 30+ years will not show the instantaneous differences as compared with newer apps. The newer apps are based on using the FFT (Fast Fourier Transform) whereas older apps may use either bandpass filtering or zero crossing counts to measure frequency differences. The zero crossing technique goes like this: let's say that you want to measure 440 Hz. There are two zero crossings per sine wave, so in one second you have 880 zero crossings. If the 440 Hz tone (assuming all other partials filtered out infinitely so) is now 1 cent off, which would be 440.25 Hz. There are 1761 zero crossings in 2 seconds at 440.25 Hz. That means that you have to wait 2 seconds to detect 1761 zero crossings to get to a 1 cent-accurate measurement. If you want a 0.1 cent accurate measurement, you would need to detect 20 seconds of zero crossings. So the zero crossing technique simply estimates the 0.1 cent and cannot directly measure it. However, using the FFT like the newer apps, lets say the sample rate is 32 kHz, and so in one second you use a 32k-point FFT which gives you 16K frequency bins per second, making that spacing 2 Hz per bin. Then you use an interpolation technique such as is well known to FFT engineers and that gives you 100's of points between 2 Hz bins, or milli-Hz resolution in one second. It also gives you continuous overlapping readings every couple hundred milliseconds, giving the user visibility on an ongoing basis to see things like jitter and pitch decay. This kind of visibility is NOT possible with the older zero-crossing apps. Hope that helps explain what you vs others are observing with other apps.
Kind regards,
Steve
Steven Norsworthy
(619) 964-0101
Sent: 03-19-2024 13:13
I have had Pianosens for a couple weeks, but it was a light tuning time (and I am not doing that much tuning these days) so have only tuned about 4 - 5 pianos with it. I will make a few initial comments (I may do a more detailed review later):
It maybe adds five more minutes to the tuning time all told in setting up, moving the sensor around and whatnot. This time is largely made up by not needing to move around the phone to get the mic placement better. Logistics aren't as bad as I imagined, and easy to adapt to (eg, the hand is already moving the mute, so shifting the sensor isn't that much more). It would be nice if the mic wire from the sensor (hard wired) that goes to the preamp wasn't so long. It has to be kept coiled up, and takes up that much more space.
I thought I'd compare display results for some individual strings by toggling between plugged in and unplugged, but that isn't practical. It takes quite a while for the phone to figure out it needs to change input, so there is a big time delay. I have an iPad with RCT on it, so will do them in parallel next time I have an opportunity. But my sense is that the display is comparable in being clear (not jumpy) for most notes, but significantly better than mic for the more problematic notes. (If the sensor placed away from the termination, the display can actually be more jumpy than with a mic - interesting. But the vibrations at the termination are what get conveyed to the bridge. Looking at high speed video, you can see the shiver of the upper partials at the inner parts of the string, like the strike point, but they have a clearer and more defined pattern at the bridge pin).
Some mention the top octave. Using RCT, I don't find that dramatic a difference.
I have tuned unisons to the RCT for many years, so that I could clearly establish the stability of each string. No difference here except when there is a string or two that are displaying less ambiguously with the sensor. (Of course, I use my ear to verify, but I use the ETD to correct when I decide it needs refining).
IMO, while there is at least a noticeable improvement overall in precision of display and ability to refine a tuning, the main and quite useful benefit is the fact that it isn't listening: it doesn't care if there is a leaf blower, a furnace fan, a vacuum cleaner, stage crew setting up, even musicians warming up while you are trying to finish the concert tuning. It is essentially a high quality pick-up, and is only responding to the movement of the string.
I had hoped it might be helpful for harpsichord and clavichord, but was disappointed at least in initial trials. I knew it wouldn't pick up the brass strings, but it wasn't that great for the steel ones (if there was more resolution, it was subtle).
fssturm@unm.edu
http://www.artoftuning.com
Sent: 03-17-2024 12:21
Rick,
Besides "preferring it for the top octave" I'd like to know: Does it slow you down, or can you see it increasing tuning speed, or neither? (After time) Also, if someone trained either as a top level technician or as a high level performer would probably notice a 'higher level' tuning? Lastly, was it easier to use than your Verituner in general? Thanks!
Sent: 3/17/2024 11:35:00 AM
Thanks for sharing your experience Rick. It's very helpful. I'd be interested in how it works on a spinet.
"That Tuning Guy"
Scott Kerns
Lincoln, Nebraska
www.thattuningguy.com
Sent: 03-16-2024 19:22
Here is my first piano tuning experience using PianoSens. I am using Verituner for Android on a 2023 Moto G Play running Android 12.
Having reviewed the instructions in advance, I connected the devices and wires in the order given in the written instructions and confirming the gain setting on the preamp as 8. I then opened Verituner and everything was running as it should be, with the Verituner receiving the signal from PianoSens.
The piano was a Kawai GE-1. So it is an older, and a very small scale grand. Since I needed to create a new tuning file, as usual I had to allow for some extra time for Verituner to acquire the inharmonicity data. I did notice that on average, the time needed for the inharmonicty "I" indicator to fill up was less than when using the microphone. A couple notes did hang up a bit, but fewer than usual. On average, without a doubt it took Verituner less time to get all the inharmonicty data into memory. Reviewing the inharmonicity data afterward, none of the notes had any spurious values they occasionally get using the mic indicating they need to be remeasured. So some time was saved there.
Since I work the tuning strictly with mutes rather than a temperament strip, in this short piano it was sometimes a bit crowded because due to the plate shape I wanted to sometimes put the mutes in the same place the sensor needed to be, but I can see I will be able to figure out ways of adjusting my technique,using different mutes, and getting it into my body memory so it all works. I am not worried about it. And on a different piano the mute positions will be different.
This particular piano had its share of pitch oscillations caused by less-than-perfect terminations or other issues. Throughout most of the middle I felt I was getting pretty similar pitch readings with the sensor as I get using the mic. There were sometimes oscillations or jittery readings, but you could hear they were really happening at the string, and the sensor was just transmitting what the string was doing. If it were in mic mode it would have been worse, because it would have also been picking up various "in the air" acoustic effects also. For instance my Android device has microphones top & bottom, while the bottom mic is aimed at the soundboard, the top mic is hearing reflections off the underside of the lid. That has to be creating acoustic confusion with all kinds of phase cancellation or comb filtering effects. So overall, the PianoSens pickup with its focus on only the string just has to work better in that regard.
It also became clear what a pleasure it was to place my ETD wherever I wanted to based on visibility rather than having to take into account whether it is also well positioned for the microphone to pick up the sound.
The biggest "aahhhh moment" however was in the high treble. Up where your ear is hearing all kinds of beating you can't tune out of it, and the indicators on the tuning device are having the hardest time locking in. With the PianoSens, despite all the aural confusion, I was getting nice steady readings on the ETD. Really a pleasure. Then the capper was the top few notes where my device is just all over the place and unable to lock on anything in mic input mode. And aurally there is so much false beats confusion. With the sensor working I was getting not only a clear, locked-on pitch signal, but it was actually sustaining a bit and remaining locked onto the pitch.
So overall, based on my first tuning using PianoSens, I feel kind of like it is "worth it for the top octave alone" but with so many other improvements over aural or mic input ETD, it's kind of a "no-brainer". Can I get a great sounding tuning without it? Yes. But it feels like I will be preferring it, for sure.
Rick Clark
Carlsbad
(760) 436-3322
