installing a two-tank PLSS on a Bosendorfer model 225
  • 1.  installing a two-tank PLSS on a Bosendorfer model 225
    Posted 24 days ago
    I will soon be installing a two-tank Piano Life-Saver System in a Bosendorfer 225 (ca. 2010). Although I have not seen the beam configuration under the soundboard in this particular Bosendorfer, I expect that the beams are in a "grid" configuration (as opposed to the more common "fan" configuration), like the two other Bosendorfers in which I have installed PLS systems. The "grid" makes fitting in the various components--at the recommended distances from each other--more of a challenge than usual.
    If anyone has any experience-born advice on how best to lay out the components, and other tips for working in these relatively tight spaces (I am already armed with a stubby Philips-head screwdriver!), I would very much appreciate hearing about that.
  • 2.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 24 days ago
    If they still use those self drilling screws with the bolt head, I would bring a nut driver of the appropriate size if your multi-tip screwdriver doesn’t already have one. Even a box wrench or a small ratchet with a socket could be useful as well for these.
    Luke
    Sent from my iPad
  • 3.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 23 days ago
    Great to hear from you, Luke! Suggested tools (that I didn't already have) on order.
  • 4.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 24 days ago
    A 90 degree drill attachment ( find a cheap one at any home improvement place, or Milwaukee makes a nice one, but any will work,) and the appropriate nut driver tip, and you can work in any tight space.  Use the lightest screw gun you have, insert hex shaft into it, and installing the screws is a breeze. You will have to remove your hat when under the piano, however.
    I did have to install a unit on a 1960's Mason A recently, that had a grid frame Plus the Tension resonator, and it fit, though the tank had to be mounted in line with the keyboard instead of front to back.  Cheers!
    David Graham,RPT
    Graham Piano Service, Inc
    Sycamore IL 60178
    815-353-5450
  • 5.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 24 days ago
    Thanks for these tips, David. And yes, I shall seriously consider removing my hat!
  • 6.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 23 days ago
    Hi Alan,
    You probably have something like this already, but just in case...
    I bought a 12volt DeWalt drill/driver which is small enough to fit into these tight spaces. Works wonders on a Steinway B.
    I also bought a DeWalt 90° adapter which has paid for itself many times over. Add in a few 1/4" bits and you are all set.
    Like I said, you may have a setup like this already, but someone reading this may benefit.
    Good luck, for a big of a beast as they are there is not a lot of elbow room under there.
    Jeffrey W Cutler
    University of Wisconsin, Eau Claire
    University of St Thomas, St Paul, MN
    Music expresses that which cannot be said and on which it is impossible to be silent - Victor Hugo
  • 7.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 22 days ago
    From pianolifesaver.com (Tech Portal)
    --Cy--
    Installation schematics for Boesendorfer PLS systems
    Cy Shuster, RPT
    Fairfax, VA
    http://www.shusterpiano.com
  • 8.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 21 days ago
    Thanks for this, Cy. Melanie posted it to the PIanotech side of this discussion.
  • 9.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 21 days ago
    My friend and colleague Ed Whitting sent the following, useful response to me personally. Hehas given me permission to share it with the group.
    Dear Alan, watch your texts, I will be sending pictures of my tools and, I don't own a stubby Phillips.
    If the support beams are painted black I use screws as supplied.  If they are beautifully clear finished spruce I use wire ties to hold everything in place.  The most critical point is the orientation of the humidifier tanks to one another because of the connecting tube.
    It is much easier to place tanks on the hanger rods if they are cut to the right length.  I use bolt cutters.
    Note: put the plastic rod hangers on the rod, in the right direction before cutting the rod; the bolt cutters deform the rod at the cut point enough to make putting them on later very difficult.
    I Use a 1/4" nut driver that has been magnetized for putting in the screws.  Some use a portable drill, I don't.  I also have a magnetized socket and ratchet that gets into tight places.
    Dry fit everything.  I put in the dehumidifiers first, then plan the tanks and humidistat. Plug in the 3 point electrical connector and plug in something on both sides of the humidistat so you know how much room you need for the connected humidistat.
    Use the Velcro to hold it in place while you determine if there is enough room to unplug everything: Trial and error.
    If using wire ties, mount the dehumidifiers in their plastic keepers. Go around the dehumidifer and beam make it med., tight , cut off the waste rend but leave enough do you can pull it tighter on your next visit.  It takes longer to install this way.
    Install the complete system but don't cut the tank connecting hose until everything else is in place.  I put the low water sensor in the 2nd tank; it just seems mechanically correct.
    Bring 2 gallons of distilled water
    Watch for tool pictures
    Hope this helps.
  • 10.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 21 days ago
    regardless of what type of water you use it's very important to use the pad treatment. Using distilled water without the pad treatment can cause the system to not function correctly. Distilled water will not conduct electricity appropriately
    Garret Traylor
    Trinity NC
    (336) 887-4266
  • 11.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 21 days ago
    Good point, Garret. I followed up with Ed about this one, and he said that he only uses distilled water for the initial installation. After that, normal tap water and the PLSS juice.
  • 12.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 21 days ago
    At least where I live, tap water has lots of minerals, so it will lead to the pads having a short life. Better to start with tap water (for its electrolytes), then use distilled water thereafter. The electrolytes won't go anywhere. Or use distilled with the treatment liquid.
    If you start with just pure distilled, the water level light will blink constantly, as will the pad light. (The unit will function fine, as long as you don't worry about the lights, and reach under the piano to feel for water level).
    Youtube Spotify Deezer Apple Amazon
    www.artoftuning.com
    "We either make ourselves happy or miserable. The amount of work is the same." - Carlos Casteneda
  • 13.  RE: installing a two-tank PLSS on a Bosendorfer model 225
    Posted 21 days ago
    I had several units for some years in studios at CSU Long Beach. At some point, a PLSS employee told me to use distilled water with a little pinch of salt. Plenty of the electrolytes to make the system work, and I used distilled water plus the juice, and I thought I had a lot less crust on my pads when it was time to change them.
    Kathy
