This feels like a very simple thing, and I've read up on the various tricks, but I wanted to ask around. Not sure if I've posted this in the right section - mods please don't hesitate to move it if need be.
For the first time - I have gone to tune a piano and the pins unscrew themselves when I let go. Even if I leave my hammer on the pin, it will rotate counterclockwise on its own. Mildly frightening.
I am going to grab some pin tite, I started with two failed CA applications. At this point in my career I have the skill but don't have a place to tip, remove, bore and change out all the pins - so I would happily send this to a fellow tech when it comes to that!
Just on the topic of pins, I've had slippery ones, loose pins and tight ones.. I've never seen them pull so quickly! Even bumping them by accident sent them down an octave. I'm not crazy right, they are compromised?
the plate/block has like 6 hex bolts running through it, I would assume a repair for stripped plate screws or just a cheaper Aeolian way of manufacturing.
full disclosure: this is an Aeolian player that is at least 100 years old I think. I see signs of previous action repair, replacement and decent maintenance!
Thank you for any tips, stories or encouragement. I've done my due diligence researching player piano guts and specs. I thought either if we save or ditch the player, the piano itself needs some TLC
Tom Delmonte
Buffalo NY
(716) 352-5607
