I didn't see your post until now. With CA glue, I have both pounded and screwed the pin back in. It doesn't seem to make a difference with the possible exception that pounding it in can make it jumpy where screwing it in seems to help it tune smoothly. With a shim, I pound it in until the shim is where I want it, then screw it the rest of the way.
The CA doesn't kick off as soon as it hits the q-tip. Perhaps it's not cotton. It doesn't even dry fast with accelerant.
Here is a video I made the first time I tried it. The pin block on this piano was supposedly going to be replaced in a couple years and they wanted me to get a few pins to hold intil then. I thought it was the perfect opportunity to experiment. It has since lasted several years. The rebuilding was put off. Forward to 1:30 in, I think.
Sent: 03-07-2024 14:05
Subject: repairing oversized tuning pin hole with plug
Maggie, two questions.
Do you pound or screw the pin back in?
Doesn't the CA kick off as soon as you apply it to a q-tip?
Sent: 03-07-2024 12:52
Wow! I've experimented with removing the pin, using a q-tip to put a layer of CA in the hole, then replacing the pin after it dries. It has been working for me WAY better than just dropping it in as you describe, but I've done that plenty. I've not had the same luck as others with it, so I avoid it these days, but many others swear by it. I think it's because I'm working with pins that are far more loose than most deal with. Not sure. Sorry for the side track of topic but thanks for the clarification!
Maggie Jusiel, RPT
Athens, WV
(304)952-8615
mags@timandmaggie.net
Sent: 03-07-2024 12:14
Thanks for requesting clarification of my somewhat ambiguous explanation, Maggie!
Personally, I apply the CA to the base of the pin just under the coli (i. e., above the pin block).
However, I have heard of other techs inverting the piano (if a grand) and applying the CA from (what would normally be) the bottom of the pin block.
Sent: 03-07-2024 12:02
Hi, Alan! Would you mind clarifying what you mean by "base" of the pin? Do you mean the base of the exposed pin just below the coil, or do you mean the actual base of the pin down under? Thanks!
Maggie Jusiel, RPT
Athens, WV
(304)952-8615
Sent: 03-07-2024 11:59
Back in the day, I used finer grit sandpaper as a shim for this (paper side towards the tuning pin, as someone has already mentioned in this thread). Never found it necessary to use glue. Always pounded the pin in to the desired height (removing the action and supporting the pin block in grands).
But for many years now, thin CA glue applied at the base of the tuning pin has solved the vast majority of loose pin issues that have come my way. It's much quicker (and therefore less expensive for the client), and in the 1% of cases in which CA doesn't do the trick, a shim can always be done. Because of the high success rate of CA, it is always worth attempting first in my experience. (Blessings upon whoever realized the utility of CA in our work!) YMMV
Sent: 03-07-2024 11:31
Hi All,
Just want to add 2 cents. Although all the suggestions are good, I'm wondering about the original attempt to "glue" in shims. When I have used shims in the past, I've never bothered to use glue. If you're trying to glue the veneer in place first, it won't work. If the fit with the shim is properly tight, the pin will draw the shim (or 2) in. You put the shim(s) in 1/2-ish of the way, then hammer the pin in. When the shim is at the right level, you screw the pin in the rest of the way. I know people don't like screwing the pin in, but I've done this several times with great success. Recently, I used one of those old metal shims, also with great success. Before doing anything more drastic, I'd consider trying to shim in this way. Otherwise, the glue methods are also a reasonable suggestion. I have had less reliable success with glue, so avoid it these days, but still have had success with it.
Good Luck!
Maggie
Maggie Jusiel, RPT
Athens, WV
(304)952-8615
Sent: 03-07-2024 08:07
A spade bit is a poor choice for drilling an existing hole: use a twist bit or a forstner bit
Sent: 03-06-2024 18:12
I meant .509 Inches. 9 thousandths oversize. I don't think you'll find 17/32 in a spade bit. The flat faces sanded on the plug should mitigate against glue starving.
Sent: 03-06-2024 14:26
I think you mean .504 just over 1/2 inch. On advice of Tim Dixon I drilled using 17/32 for 1/2 plug. Then bore bottom flat with Forstner bit.
Epoxy is best. Do not drill 1/2 hole for plug. You will glue starve the joint. I also like to preheat my plugs to ensure maximum dryness. An
old plate warmer works well.
Sent: 03-06-2024 13:25
The Falconwood plug I am holding in my hand measures 5.009 inches in diameter. I just grabbed a cordless drill, chucked up a 1/2" twist drill and bored into a 2x4. That's a bit of a sloppy way to drill. The plug was a tight fit in hole, but it could have been hammered in. A bit of file work on a spade bit will allow you to tweak your hole diameter if necessary. Sanding some flat faces, maybe 6 or so, around the circumference of the plug will allow you to localize the interference, and will also make a bit of room for the adhesive in the joint.
Sent: 03-06-2024 12:22
Bill,
I tend to use System Three Epoxy for this, though I suspect West System would work just as well (perhaps with the slow set hardener).
T-88 is a very strong epoxy from System Three
Sent: 03-06-2024 12:13
Thank you all for replying to my post with great ideas. I've got some delignit plugs arriving from Allied Piano and I'm going to do some testing on an old pin block first. I'm going to try the method of filling the hole with epoxy and drilling a new hole through that. What brand or type of epoxy do you use Peter? I'm also going to experiment with the plugs. How do you drill for an interface fit Floyd? And thanks for the idea of using the spade bit.
Bill
William Ryder RPT
Arcata CA
(707) 822-3319
Sent: 02-29-2024 16:16
Hello,
I am trying to repair an oversized tuning pin hole in a Steinway grand. I have tried gluing wood veneer shims to the sides of the hole, to no avail. At present I have a 5/0 tuning pin in there that is not holding pitch. I think my best option would be to drill a larger hole in the pinblock and insert a maple plug. However, the tuning pin holes in Steinway plates are very small, especially in the bass. I feel it would be best to enlarge the hole by drilling from underneath the pinblock with a right angle drill. Has anybody ever done this? This is an old S&S model C that was completely rebuilt maybe 20 years ago. I think there may have been some issues with the drilling of the new pinblock. Anyway, the owner of the piano gave me a piece of left over wood from the pinblock installation that I can use to make a plug.
Please let me know if you have any ideas that would help. Thank you.
Bill Ryder
William Ryder RPT
Arcata CA
(707) 822-3319
