Tuning pin torque measurements revisited
  • 1.  Tuning pin torque measurements revisited
    Posted 25 days ago
    Hello, all.
    Reading back through various posts over the years, I notice there seems to be a number of schools of thought about how tuning pin torque should be measured.
    Averaging clockwise/counterclockwise, with strings, with no strings, etc.
    Averaging seems logical, but doesn't seem to pan out in reality. Say there is a lot of rendering resistance pulling up (clockwise) but very little in the downward/push direction (counter-clockwise). For example, a grand piano in a practice room here reads 85in/# in the pull but less than 15in/# in the push direction. The pin doesn't hold over even a short time, but averaging them, math says this should be fine: 80+15 = 95/2 = 47.5. Minimal but should hold. Subtracting 80-15 = 65; should definitely hold. Removing the string eliminates resistance, but can't tell you what the factors of string rendering would be, and they are considerable.
    Has anyone come up with a better method of determining real torque; not just what it should theoretically be, but how to arrive at it in real life? Perhaps down torque as a percentage of pull torque or net torque. Maybe this has already been satisfied, but I can't find it anywhere, just a lot of discussion. I have historically made this determination by manual manipulation, but I want to be able to present and support my findings in a way that is quantifiable.
    Dave
    Dave Conte, RPT
    Piano Technician in Residence
    The University of Tennessee
    College of Music
    Knoxville TN
    (817) 307-5656
    Owner: Rocky Top Piano
  • 2.  RE: Tuning pin torque measurements revisited
    Posted 25 days ago
    I have always considered down torque most important with a reading of 80 inch lb as a minimum.
  • 3.  RE: Tuning pin torque measurements revisited
    Posted 25 days ago
    Torque measured in the sharp direction (pulling the string sharp) will vary with the tension of the string, and the same will be true in the flat direction. When restringing, we can set a target torque for the pin without the string attached, but feel of the pin will vary as the tension scale varies.
    The most important measurement from the point of view of holding a tune is in the flat direction, so I would say you could set a minimum figure there (30 - 30 inch pounds?). As for both directions, I recall an article by (I think) a technical editor of the Journal (Jack Krefting? Steve Brady?) giving ranges of torque for tunability, but a search of the Journal index didn't find it.
    www.artoftuning.com
    "Travel is fatal to prejudice, bigotry, and narrow-mindedness." Twain
  • 4.  RE: Tuning pin torque measurements revisited
    Posted 25 days ago
    I found something in the 2016 Journals. In my full-year 2016 this material occurs after the December issue. Perhaps it was an add-on.
    It's an unusual layout. Here's the cover page:
    Here's the one page of about 20, the one most relevant to what you're discussing?
    Jason Kanter
    Lynnwood WA
    (425) 830-1561
  • 5.  RE: Tuning pin torque measurements revisited
    Posted 25 days ago
    Larry Nobel did a pair of articles in February (p 14) and March (p 13) of 2020, seemingly connected with that odd 2016 "Piano Tuning Pin Study" prospectus, which doesn't appear in the Dec 2016 Journal (don't know how it got appended to that PDF of 2016). Lots of good info.
    Lobel's article references an article by Nick Gravagne in January 1993 p 24, which has a lot to say about tuning pins and torque.
    www.artoftuning.com
    "Art is not a mirror held up to reality, but a hammer with which to shape it." Brecht
  • 6.  RE: Tuning pin torque measurements revisited
    Posted 24 days ago
    Thank you, Jason.
  • 7.  RE: Tuning pin torque measurements revisited
    Posted 24 days ago
    Dave,
    Do check out Larry Lobel's articles, Feb and Mar 2020 Journals. They are very informative, and include exactly what you were asking for. Easiest way to access them is the Journal Archive  https://my.ptg.org/journal/journal-archive
    www.artoftuning.com
  • 8.  RE: Tuning pin torque measurements revisited
    Posted 24 days ago
    Hi, Fred. Yes, I just looked at them. Thank you for your efforts to dig into this for me.
    Dave
  • 9.  RE: Tuning pin torque measurements revisited
    Posted 23 days ago
    Lots of useful information. Still think there should be a protocol for this.
    How do manufacturers measure this? Probably piano is not strung. But that doesn't help when trying to evaluate an older (or failing new) piano. Torque plus 35"/# is probably a reasonable guess, but so many variables; counter-bearing and string rendering among them. And if the pins are contacting the plate webbing, all bets are off anyway.
    I am attaching a photo of a simple jig I made to demonstrate pin torque to students, et al, which enables varying the torque by means of a through bolt. The pin is in a piece of maple but continues through to a larger "plate" to clamp the jig down that is the same diameter as the tuning pin so it does not add to torque resistance. One of the issues I am dealing with is the slop in the torque wrench assembly. Where can I get one that has a tight connection between the lever head and the socket attachment?
    Comments are welcome as I work on developing protocols and a better jig and measuring device.
    Dave Conte, RPT
    College of Music
    Knoxville TN
    (817) 307-5656
  • 10.  RE: Tuning pin torque measurements revisited
    Posted 23 days ago
    Dave Conte, RPT
    College of Music
    Knoxville TN
    (817) 307-5656
  • 11.  RE: Tuning pin torque measurements revisited
    Posted 19 days ago
    Yes, those were an add-on to my 2016 Journal articles; they were from a slide show I gave on the Tuning Pin Symposium I conducted at Sonoma State University.    I can send the full slide show to anyone who wants it.
    Also to reiterate the point about measuring both up and down torque; Paul Larudee, inventor of the Lo-Torq tuning pin, wrote that torque readings taken in only one direction is akin to giving a touchweight value that only takes downweight into account, without an upweight value.
    Larry Lobel RPT
    San Francisco chapter
  • 12.  RE: Tuning pin torque measurements revisited
    Posted 19 days ago
    Hi, Larry.
    Thank you. Having the slide show would be beneficial.
    I devised a simple device to measure variable unstrung torque for demonstration purposes,
    I posted a photo but can't find where it populated. Maybe it was disallowed? Heaven only knows.
  • 13.  RE: Tuning pin torque measurements revisited
    Posted 18 days ago
    I've been trying to paste a link here to my 2016  Tuning Pin Symposium slide show, but haven't been able to make it work.  I'll keep trying.  In the meantime Dave, I'll send it to you individually, maybe that will work.
    Larry
    Larry Lobel RPT
  • 14.  RE: Tuning pin torque measurements revisited
    Posted 18 days ago
    I'm attaching a .pptx (Powerpoint) file with the full slide show of my 2016 Tuning Pin Symposium (attachment below)  If you double click on it, it will download onto your computer so you can open it.
    Larry Lobel RPT
    pptx
    TuningPinSymposium.pptx   7.12 MB 1 version
  • 15.  RE: Tuning pin torque measurements revisited
    Posted 18 days ago
    Hi, Larry,
    This came through perfectly.
    Thank you very much.
    Kind regards.
    Horace
    On 4/30/2024 3:42 PM, Larry Lobel via Piano Technicians Guild wrote:
    > I'm attaching a .pptx (Powerpoint) file with the full slide show of my 2016 Tuning Pin Symposium. I hope this works.
    > Larry Lobel RPT
    > Original Message:
    > Sent: 04-23-2024 19:10
    > From: Jason Kanter
    > Subject: Tuning pin torque measurements revisited
    > Jason Kanter
    > Lynnwood WA
    > (425) 830-1561
    > Original Message:
    > Sent: 04-23-2024 17:28
    > From: Fred Sturm
    > Regards,Fred Sturmfssturm@comcast.net <fssturm@comcast.net>www.artoftuning.comhttp://fredsturm.net"Travel is fatal to prejudice, bigotry, and narrow-mindedness." Twain
    > Original Message:
    > Sent: 4/23/2024 5:05:00 PM
    > From: Parker Leigh
    > Subject: RE: Tuning pin torque measurements revisited
    > Parker Leigh RPT
    > Winchester VA
    > (540) 722-3865
    > Original Message:
    > Sent: 04-23-2024 12:02
    > From: Dave Conte
    > Hello, all.
    > Dave
    > Dave Conte, RPT
    > College of Music
    > Knoxville TN
    > (817) 307-5656
    > Reply to Sender : https://my.ptg.org/eGroups/PostReply/?GroupId=49&MID=774996&SenderKey=38256bbf-0599-4bf8-b86a-149cba21e5ce
    > Reply to Discussion : https://my.ptg.org/eGroups/PostReply/?GroupId=49&MID=774996
    > To Download the attachment(s) click on the link below:
    > https://my.ptg.org/eGroups/ViewAttachment/?DocumentKey=99a51146-3f6a-4843-b3b6-018f312c0533
    > (if the link doesn't work, copy and paste it into your web browser)
    > You are subscribed to "CAUT" as horacegreeleypiano@sonic.net. To change your subscriptions, go to http://my.ptg.org/preferences?section=Subscriptions. To unsubscribe from this community discussion, go to http://my.ptg.org/HigherLogic/eGroups/Unsubscribe.aspx?UserKey=18d8c323-aa1d-4526-8bf1-a6805870cbe6&sKey=KeyRemoved&GroupKey=e03c48ae-bba7-4045-9d5f-c5e4b7b46b15.
  • 16.  RE: Tuning pin torque measurements revisited
    Posted 19 days ago
    I like to see minimum down torque with the piano strung at pitch.  My factory experience at Bosendorfer was that most new pianos had torque
    over 150 and many closer to 200 inch pounds.
