The only threaded damper wire I ever saw was on late-19 Century Chickering grands from the top of the wire into the damper head. Thank, but no thanks, to whosoever's idea it was, I saw no use for its delicate fine-tuning of the head's lateral position
Sent: 12-16-2023 19:57
Subject: Advice for Damper Head block
Hi, Bill!
Spot on.
Thinking of nomenclature, when I first glanced through the OP, I instantly thought of Chickering's damper wires...threaded where they went into the damper lifter ("barrel" in the OP).
Use of threaded brass barrels was not universal outside of Steinway. A number of makes had their own variations on the screw-into-raw-wood theme.
Kind regards.
Horace
Original Message
Sent: 12/16/2023 7:39:00 PM
Subject: RE: Advice for Damper Head block
Can we clear up some nomenclature? What you call the "barrel" (connecting the damper wire to the damper head) sounds like the damper post (the vertical block wood which holds the bottom end of the damper wire, which itself is pinned to and pivots on the horizontal damper lever. What most of us know as the "barrel" is the brass cylinder, installed horizontally in the post, with a vertical hole through it, to hold the bottom the bottom end of the damper wire. The barrel also has a threaded horizontal center for the set screw to hold the damper wire in place.
For all of the 19th century, Stwy damper posts had no barrels, simply the threaded set screw. Over the decades, the threads in the wooden post, put there by the set crews, would strip, or worse, turning the set screw would split the post.
If that is your situation, it's a common one, for which there will be many suggestions.
