  • 1.  Artist Bench Vinyl Repair
    Posted 07-14-2023 09:40
    Does anyone have a favorite product for repairing vinyl tears in artist benches?
    Luke
    Sent from my iPad
  • 2.  RE: Artist Bench Vinyl Repair
    Posted 07-15-2023 14:36
    Hi
    On vinyl If you have a small/tiny hole you can just use VLP glue.  If the hole is bigger you can cut a patch that will stuff into/under the hole and apply the glue to the underside of the top through the hole around the edges.  The glue melts the vinyl together.  You can sometimes find enough vinyl in the bottom edges of the top to use as a patch.
    Sent from Gmail Mobile
