Where did that come from?
I was illustrating that the skills required for soundboard making and voicing are the same for solving a noise issue. And I was just using a little humor to express it.
All the elements are known, and yet no combination there of creates life. Yet we are here.
Sent: 08-25-2023 14:16
Subject: Backcheck noise on Bosendorfer mystery
Roger
LOL I believe it is Chris's pathetic attempt to make a joke about my previous discussions on hammer selection using soundboard impedance as a one criterium. He believes, evidently, that impedance is a myth and doesn't exist. Goes hand in hand with the belief that the universe is only 6000 years old. but I should let him explain.
Sent: 08-25-2023 11:09
Chris,
What is linear or non linear acoustic impedance?
Roger Gable RPT
Gable Piano
Everett WA
(425) 252-5000
Sent: 08-24-2023 13:46
If you listen to the acoustic impedance and determine if its linear or non linear it may assist you.
Sent: 08-24-2023 12:36
I like Mr Roeder's suggestion but would go one step further and drill a small hole through the mounting block into the key and insert a screw. Try that on a few samples that are making the noise. An alternative is to use small Miller dowels that are tapered and can be cut flush with a Japanese pull saw The dowels and special drill bit can be purchased from Rockler and/or Woodcraft
