Existing key balance rail pins are 50mm (2 inches) in length. Seems only 2 1/4 inch replacements are available. Well at least I can't find a source for 2 inch pins.
So if I use the 1/4 inch longer replacements, only a dozen of so need to be replaced, how best to deal with the longer length? Drilling deeper holes is not an option.
So it seems I have 2 options, leave the new pins sitting higher than all the originals, which will look amateurish. Or cut the replacement to length, meaning the bottom cut surface won't be nickle plated.
Thoughts.
John
John Woodrow
PENSHURST
