  • 1.  bass string makers
    Posted 07-20-2022 09:01
    greetings,
    i usually get my bass strings from JD Grandt, but they won't be starting after August 15, so probably looking at sometime September for the strings to arrive.
    Since i don't have time to wait (moving), i am looking for a very good alternative. I like JD Grandt's Paulello wire a lot.
    The bass strings are for a 5'2" Chas M Stieff grand piano ( I also need the scale of the plain wire strings since the piano came with all plain wire strings removed, so I'm clue-less).
    Which are the bass string manufactures that can compete with JD Grandt's quality that I can contact?
    Thank you,
    Peter
    Petrus Janssen
    Peachtree City GA
    (678) 416-8055
  • 2.  RE: bass string makers
    Posted 07-20-2022 10:34
    Hi Peter,
    I routinely purchase bass strings from GC Piano in Ontario.  (416) 755-7109  gcpiano@rogers.com
    I have been very pleased with the product.
  • 3.  RE: bass string makers
    Posted 07-21-2022 00:39
    JD Grandt, GC, Gregor Heller all do great work.
  • 4.  RE: bass string makers
    Posted 07-21-2022 09:22
    Petruss,
    I have the original plain wire scale for a Stieff Scale 32 grand piano. I also have a re-scale for this piano if you would like it. To implement my re-scale you would have to recap the bridges and notch new unison lengths, however.
    I, also, would go with G.C. Piano Co. bass strings.
    Dave Hughes, RPT
    David Hughes RPT
    Vintage Case Parts
    Glyndon MD
    (443) 522-2201
  • 5.  RE: bass string makers
    Posted 07-21-2022 11:06
    Another source to consider is James Arledge. When I needed bass strings for a Stieff he came through. I had to do a string tracing but as I read the measurements off he realized we had the same stringing scale.
  • 6.  RE: bass string makers
    Posted 07-21-2022 11:45
    Hello James,
    I tried several times calling him but nobody picks up and his voice mail box is not setup.
    Peter
    Petrus Janssen
    Peachtree City GA
    (678) 416-8055
