Some questions please:
1) You have scrupulously checked all glue joints in the vicinity of the bass bridge...yes?
2) Have you removed one string (for example), checked for twist in the appropriate direction...if none found twisted in appropriate direction, re-installed and compared its tone?
3) Did this condition occur over a short period or a gradual long period?
4) Did the piano sound GREAT when brand new or simply OK when new?
Sent: 08-11-2022 17:52
Subject: Bass strings have gone tubby and dull
It is certainly possible that it was a bad set of bass strings, &/or that they were poorly installed (without the twist to keep the windings tight).
It is also possible the particular desiccant she used contaminated the bass strings, causing their deterioration. Pianos often ship with desiccant pouches, which may remain if the technician doesn't dispose it (which they should). MusicSorb is a desiccant product designed/marketed for use in pianos, so there are desiccants that are safe for pianos.
