I heard back from a violinist who checked with some others about rosin residue. Seems like a soft toothbrush followed by alcohol wipes and immediately wiping strings dry using a swiping motion. However she said the wound strings are steel wound and others are gut...
I know things happen but the piano is a percussion instrument and not a string instrument. I think a bill for a full set of new wound strings plus the labor to remove the old ones, install, chip tune, multiple tunings to stabilize the new strings sent by registered mail to the genius that experimented with the bow will put an end to the nonsense. If you need to control access to the pianos consider performance locks and lid locks. Another idea is have a designated piano that all of the experimenters can use to do their research/experiments on.
Another thing to be aware of is the practice of taking the lid hinge pins out and removing the lid ala the 5 Browns. Happened at a local music school next person came along lifted the lid on an S&S D and launched it.....
Sent: 06-30-2022 14:01
Subject: Best way to remove rosin from the bass strings
I have been watching this discussion and I am a little surprised that, except for Ed, there does not seem to be much pushback on this. I would NEVER allow bowing of a bass string on our pianos. I don't believe one can clean all the resin out of the windings and alcohol or other solvents will only increase the chance of increased problems. I think there comes a time we need to say no. I am not willing to sacrifice the quality of a piano for 99% of the users to satisfy the whims of 1%. Either we are the experts on piano care and longevity - stewards of a large and expensive inventory - or we are not. Sometimes money has to do the talking; send them a bill in advance for string replacement and other associated costs.
Rick Florence RPT
Gilbert AZ
Sent: 06-30-2022 07:58
I wouldn't use any solvents, as they will carry some dissolved rosin down between the core and winding, killing the string.
I am not sure removing it is the route of least problems, but if you had to do something, I would first vacuum off any loose stuff, and then using a. brass bristle brush, brush the strings length-wise first, with vacuum going, and then, finally brush perpendicular to the string. You don't want any more between the coils than you have to have.
Regard,s
Sent: 6/29/2022 12:26:00 AM
Subject: RE: Best way to remove rosin from the bass strings
I know a violinist and a cellist who may have ideas. Would like to see some pictures to get an idea. Usually too much liquid anything on a wound string will kill it- even excess moisture after a flood. I had to deal with a number of pianos that had sat in rooms that had been flooded out. No direct water contact with the strings but they all died probably due to rust and corrosion. Why do you think the piano will need a new pin block ? Did rosin get in that area ? What are the pin torques as measured with an inch lb torque wrench ?
