...and when putting the bridge pins back in, consider rotating them to present a fresh, unindented surface to the string. That also can help mitigate false beats.
Sent: 02-28-2023 10:11
Subject: Bridge pin repair
Be careful with the CA glue. Where a little may be beneficial, a lot will deaden the tone and sustain. In other words, you can't apply it the same way as with tuning pins. It would also help to remove the pins and strings and check the deflection angle as well as clean up the v-bar if applicable.
John Leggett, RPT
Sent: 2/27/2023 2:26:00 PM
Subject: RE: Bridge pin repair
With the single note under a strut being the issue, I would encourage you to very carefully drip some water-thin CA into the voids around the pins. This is often done without removing the wires, but I have found that approach to be problematic in more than a couple of instances. Lifting the strings out of the road, and administering the CA should give you much improvement. Here's what I use for glue application:
https://www.amazon.com/PH-PandaHall-Micro-Tips-Applicator-Dispensing/dp/B07VVQKHDJ/ref=sr_1_3?crid=4O00C8VACKY4&keywords=glue+applicator+tips&qid=1677525915&sprefix=glue+appli%2Caps%2C112&sr=8-3
Sent: 02-27-2023 14:20
Check out "Bridge Repairs for Better Tone" in the August 2015 Piano Technicians Journal. Right down the line of what you are proposing, with much helpful detail. Also, download the index for the Journal Archive and search on bridge pins, or bridge repair. Somewhere around the time the Spurlock article was published for the first time, there were various discussions in the Journal around this issue, with variety of alternative approaches articulated.
