Thanks for the information and tips. Linked actions is a good description although I like kluge , insane and a few other descriptors. I will pull a few hammers and weigh them on my gram scale as well as pop a few center pins and examine under a microscope. Repinning after reaming will likely improve things both on the hammers and the whippens. I will followup with Ken at Cornell since he sounds like an expert. If the leather bushings are an issue I will likely recommend sending the keys out for rebushing with high quality felt. The piano was rebuilt here by a local shop but he had some strange legacy. No telling what effort was put in or not .
The intention is for this piano to be used for services and special concerts and to preserve it as much as possible. If felt is better than leather for bushings and in our humid environment it likely is so be it. The church will be investing in a woolen string cover, full dampp chaser system and padded piano cover
Sent: 08-14-2024 21:25
Subject: C Bechstein 1877 Grand
Many pianos of this vintage had linked actions: Bechstein, Knabe, and others. Not a bad design just hard to service. First, get yourself a good digital gram scale, available from Woodcraft ($60). I suspect that the hammers are way too heavy. You will need to disassemble the action to assess the keyset. Examine the plating of the pins and replace as needed. Go over all action centers, measuring with gram scale. You may want to confer with Ken Walkup at Cornell who has experience with early Bechsteins. If the leather bushings are hard, replace. Sounds like a poor rebuild.
