What Naptha can't clean the EA usually does, so they compliment each other. In shop experiments EA had good effect on light Vertigris. And because of its properties it assists in removing moisture from the felt. I have used ESN and applied a heat directly to the center pin and no explosion, so i think your'e ok. But to be safe, i would use ESN after the hotbox.
"Where Tone is Key, and Mammoths are not extinct."
Sent: 01-14-2023 16:51
Subject: Center pin lubricant
When I first started in the business in the early seventies, I worked for a Wurlitzer dealer. This solution of VMP Naptha and silicone oil was recommended to me by a Wurlitzer factory technician. They were having an issue at the time with sticky action centers on some of the new instruments which I believe was due to the bushing cloth not being properly sized. The naphtha is a solvent for the silicone oil which carries it into the bushing cloth and then flashes off. I would be curious to know what the ethyl acetate is for since it seems to be more in the line of a solvent than a lubricant. Also, because I usually treat sticky action centers by heating the action in a "hot box" with a hair dryer and ethyl acetate is cautioned for its flammability, do you think this might pose a problem? Note, naphtha is flammable as well and I've never had even littlest explosion with it.
Cecil Snyder RPT
Torrance CA
(310) 542-7108
Sent: 01-14-2023 11:27
Try my Ethyl Silly Nap. Its based on what was used in the past except i made a couple improvements. I use it exclusively now and others report back to me they love it too. You make it yourself for pennies.
https://www.youtube.com/watch?v=WHYnqsQ-FuM
Sent: 01-14-2023 09:12
My go to treatment for centers that are in good condition but too tight is VS Profelt. Soak and let dry overnight.
David Stanwood RPT
Stanwood Piano Innovations Inc.
West Tisbury MA
(508) 693-1583
