The net effect will be to lower the action ratio somewhat. that kind of change from 15.5 to 16.2 probably lowers the balance weight by 2 to 3 g if you're using the same hammers. If you're changing hammers, then you'll want to consider whether 16.2 is adequate given the weight of the new hammers. So the answer is a little bit more involved than you've given data for.
I have another thread going in which I'm doing some beta testing on spreadsheet calculations for exactly this purpose so if you'd like to participate in that contact me privately I can give you some information on how this will pan out if you're able to take certain measurements.
www.davidlovepianos.comdavidlovepianos@comcast.net415 407 8320
