That's a good idea, Steven. I believe that they are often just regular damper levers with no damper wire with an extra-strong spring. It seems that that would be pretty easy to install. I have been in contact with a spring maker, and it would be very expensive to replicate for just a few springs.
Peter Stevenson RPT
P.S. Piano Service
Prince George BC
(250) 562-5358
ps@pspianos.com------------------------------
Sent: 08-22-2026 20:31
Subject: Console damper rod stabilizer spring replacement
A lot of American verticals with a bass sustain had something like that where the bass damper lift rod over-leaves the treble one. If memory serves they were made with an oversized flange and a modified damper lever with a heavy wire spring that clamps down under the flange screw. You might be able to cadge one from an old defunct piano, or take a good look and it and reproduce it.
