Here is a quick review of what I have stated earlier in this thread, Thomas. The balance holes are worn enough that I will have to do something more than glue sizing to resuscitate them, and wondered, if I go the route of installing a "new hole" at the bottom of the key anyway (and since I will be replacing the key pins in any event), how much trouble it would be to make the balance pins .146" instead of .162".
My sole reason for making the conversion would be convenience and precision in key leveling. I find it frustrating to use regular key punchings on .162" balance pins, as they don't slide readily down the pin, and in the process of being forced, the paper flares up around the pin. I find this condition to be annoying when trying to achieve the "still water" effect that I go for in the plane of the tops of the natural keys, and somewhat less stable as well.
Our colleagues on these lists have all but convinced me not to go for the conversion. So, now we are turning our attention to simpler ways to repair the worn balance holes than by using inserts, and coming up with a quick, clean way to open up the holes in the "center of the donut" on the balance rail paper punchings.
Clear as mud?
Sent: 01-06-2023 13:37
Subject: converting .162" balance rail pins to .146"
Hello!
I'm wondering the same thing as Fred. I see no advantage to .146 pins over .162, and new .162 pins are readily available. Is it a matter of trying to standardize your keyboards, or is there some advantage that I don't know about with thinner balance rail pins?
Just curious, wish you the best with the project!
Tom Dowell
Hulbert Piano
tom@hulbertpiano.com
262-221-0792
Sent: 01-04-2023 15:21
If you aren't replacing the keys, what motivates you to reduce the balance pin size? Seems like a lot of work for no gain.
www.artoftuning.com
"Criticism is easy. Art is difficult." Philippe Destouches
