The silver finish on the plate was a cosmetic choice I would think. Since the bearing bars are incorporated and cast as part of the plate, I doubt that an aluminum plate would work. The strings would dig right into it wouldn't they? The vogue for aluminum plates over here in the states didn't last for long for two reasons: 1. they lacked the rigidity of cast iron and were therefore an inferior product and 2. the cost of aluminum is significantly higher than cast iron and would be--even more so in Europe.
At any rate, I had to move it out away from the wall when I went to tune it and for a little spinet it didn't seem to lack, if you'll pardon the pun, gravitas.
Cecil Snyder RPT
Torrance CA
(310) 542-7108
Sent: 06-26-2022 16:21
Subject: Counter-bearing to the max
very interesting it looks like a louis zwicki stamped on the plate - exposed pinblock it would be easy to use ca glue to tighten loose pins. I tuned an Ivers and Pond grand that had a sloped webbing area going downhill . it was actually easy to tune since the plate is silver was it aluminum ?
