Hello everyone,
I'm used to use the glue-sizing method (cardinal points needling inside the hole and water-wood-glue mix 70/30) but it doesn't work everytime (wood swells then retracts overnight). So I was searching for an alternative to the more invasive fixes. I read somewhere recently the dampp-chaser liquid treatment can be used to swell the wood around the balance key hole and I've just tried it. I would say it seems to work but is it better than to glue-size the wood ? Maybe... As a matter of fact, It seems that the dampp-chaser liquid applied at the room temperature (a thin paint brush of the liquid inside the bal. rail hole) makes the wood swell enough to a better pin fit and the correct friction is preserved (the key falls in a smooth but easy way during test). Perhaps the liquid pad treatment can be more efficient at hot temperatures. I just got to make tests about it.
What's your best way to fix a moderate reamed key hole ? I often see pianos with no ''pulley'' key here but when I do the test (lift up the key back 1 – 2mm and release) often I have many keys that fall too easily with no friction at all and I can hear (but not see) a very tiny knock when I push-pull some keys.
Thank you,
Bruce SATO
QC
