Case in point.
Today I measured a Baldwin R from 1983 for hammer replacement. The hammershank center pins are 145mm above the keybed. The bass string height (1 - 26) is 202mm so subtracting 145 from 202 gives me a desired bore distance of 57mm in the bass to have the shank level with the keybed and the hammer 90 degrees to the string at impact. The original bass hammers are bored at 57mm.
The string height in the two capo sections (54 - 88) is 192mm above the keybed. Again subtracting 145 from 192 gives me a desired bore distance of 47mm. The original hammers in the treble are bored at 47mm. So far so good, nothing to see here, move along.
But wait. The string height in the mid section is 194mm from the key bed. So all things being equal (unequal?) I would want to bore these hammers at 49mm. The originals are bored at 47mm.
All the hammers were bored at the factory with zero degrees of rake so the mid treble hammers were over centering from day one. Of course since the contact area of the current hammers is roughly 20mm long it's hard to see exactly where the center really is.
So my options are:
1) Ignore the differences and duplicate what the factory did.............. not liking this one.
2) Add 1.5 degrees of positive rake to notes 27 - 53................... not thrilled about this either
3) Try and get my friends at the supply house to bore the middle section at 49mm.........probably the way I'll go if the hammer tails are long enough.
The point being that this piano has been perfectly serviceable for 40 years without a custom hammer bore. I'll try to improve it while I'm working on it because I can and because it'll make the job more fun. At the end of the day though, no-one but me will know or care.
I'm okay with that.
Sent: 02-06-2024 19:41
Subject: Does anyone adjust hammer bore distance to compensate for the string angle to acheive a perpendicular hammer strike?
Hi Roger, can you elaborate with some details about how you do this? That would be helpful to me. Thanks, Joe
Joe Burros
Cell: 646-410-7174
jbcello@gmail.com
www.fmi-newengland.com
Sent: 02-06-2024 19:38
Joe,
Yes. Always
Roger
Roger Gable RPT
Gable Piano
Everett WA
(425) 252-5000
