Greetings all,
I have a 1925 Hindsberg (Danish), which has the original Schwander-type butt springs. A previous technician had also installed American-type springs, presumably due to the weak originals. The original springs are indeed too weak to function properly, and the new springs are too strong, resulting in a 70-90-g DW. I'd like to remove the new springs and replace the originals, but as seen in the photo, the design is different than the modern version. Is there a way to modify the old butts? (Replacing all the butts, if even possible, would probably be cost-prohibitive.)
I have tried to strengthen the old springs and weaken the new ones--neither worked. De-activating a sample original spring had little effect on DW.
Any way to fix this piano? It was rebuilt a few years ago, but the spring problem wasn't addressed then, possibly due to cost.
Photo attached. Note the old spring and the way it's "threaded" into the butt, and the new groove constructed for the American-style replacement springs.
Scott Cole, RPT
rvpianotuner.com
Talent, OR
(541-601-9033
