Hi Jon,
I am always eagerly awaiting to see what you come up with next. But, i think there is an accrued error that's built in to your design.
Two Reasons:
First you set the tool on the windings and place the dial onto the top of the core. This gives you a false "zero" and the error get worse as the windings get larger.
Second, by the tool blanketing several strings the individual strings inaccuracies get covered over. Iv'e seen big angle changes from neighbors strings as i'm sure you have too.
Here's my latest and last Lowell type gauge (as i see no way to improve it after 4 modifications). It features a large bubble with 1 degree lines. So easy to read. And i have made several feet for any situation, and the height goes over any capo bar. Its spring loaded so it hugs the adjustment bolt. The bubble has a slightly slower fluid that makes seeing the smallest angles a joy. And its easy to get one at Home Depot.
Regards
"Where Tone is Key, and Mammoths are not extinct."
Sent: 08-03-2022 22:02
Subject: Down Bearing Gage
That's cool Jon, thanks for sharing!
