Ed,
I haven't looked into this for some time so my information may be out of date, but...I contacted three epoxy formulators -- System Three, WEST, and MAS -- and all three advised against thinning their epoxies with anything. They all claimed it weakened the product.
If thickness is a problem there are some epoxies that are formulated thin to begin with. The various Epo-Tek epoxies come to mind. Some of these have viscosities close to that of water.
ddf
[Delwin D] Fandrich] [RPT]
[Piano Design & Manufacturing Consultant]
[Fandrich Piano Co., Inc.]
[Olympia] [WA]
[360-515-0119]
Sent: 08-02-2022 17:50
Subject: Epoxy for Bridge Repair
Thanks, Ed. I haven't experimented with using a slower hardener - this might be a good opportunity to do that.
Peter
Peter Stevenson RPT
P.S. Piano Service
Prince George BC
(250) 562-5358
ps@pspianos.com
Sent: 08-01-2022 16:13
The West System is basically liquid fiberglass without the fiber. I usually use the slow cure hardener, as I think it gives me sufficient pot life without worrying about it. If you have every other pin pulled out, and inject the resin into all the open holes, you will have enough resin in there so that after pushing in the other pins and clamping, the squeeze out will be everywhere you need it to be to make the bridge a solid structure. You will still have time to clean up the top. I have used a handful of precut cloth strips, which after wiping off as much excess as possible, "shoe-shine" the bearing surfaces of the pins .
I haven't needed to , but I think the resin can be thinned with acetone or lacquer thinner if you feel you need more penetration. Read the instructions before doing that, though.
