Thanks for the replies everyone. Sounds like I'm on the right track.
Steven - I hadn't thought of that, and a very good idea I might try. It IS a Renner action, but on a Kluge keyset, and the piano was made in Europe, so I'm not sure Renner USA would have input. Or, perhaps there's tech support from Lous Renner GmbH?
Paul - very interesting to learn this! I read through the thread you linked, and though the over-bedding practice is accepted in certain conditions and pianos, I feel more confident that it was not incorrect for me to bed the action traditionally. Yes, key height lowered by about 2mm but I'm doing a full regulation and fixing the back action, so re-working the key height was expected. The action frame is also very stiff, unlike the Yamaha which accepts over-bedding. Also intrigued to find that the keybed is crowned like a Steinway.
Robin Whitehouse
Greenbelt, MD
D.C. Chapter 201
Sent: 02-13-2026 18:06
Subject: Estonia Regulation Manual?
Thanks for the link, Paul.
Sent: 02-13-2026 18:04
Hi Alan:
I'm repeating what i've read and heard about Yamaha pianos. I am by no means an expert. If you search this thread from some time ago, you'll get more opinions from others on Pianotech: "Adjusting Yamaha grand action glides".
Here's the link:
https://my.ptg.org/communities/community-home/digestviewer/viewthread?GroupId=43&MessageKey=3faf65b0-5bef-40fd-b61e-e431992c321b&CommunityKey=6265a40b-9fd2-4152-a628-bd7c7d770cbf&tab=digestviewer
Best regards,
Paul
Sent: 02-13-2026 14:58
Paul,
Assuming that you are referring to the "blind" balance rail glide bolts positioned between the glide bolts that appear between sections and are not accessible from above/between the keys, I question the notion that they should not be adjusted. Here's why:
1) All balance rails equipped with glide bolts are, to the best of my knowledge, designed to hold the balance rail itself off the keybed;
2) They are adjustable, and;
3) Yamaha technicians have offered advice about how to deal with these.
FWIW,
Sent: 02-13-2026 10:26
Some pianos are set up with glide bolts set so the balance rail is held off the keybed. Young Chang comes to mind. Yamaha also. Yamaha has two glide bolts that are not meant to be adjusted in the field. They set the basic height and then the other bolts are adjusted. When you change the key height by lowering the balance rail with the glide bolts, now you're going to potentially run into other problems with the "magic line" that were not anticipated. You might have to raise the key height again by adding punchings on the balance rail pins. When you do that, you might introduce some unwanted friction because the "magic line" is compromised. Some actions, like the Yamaha, have a flexible key frame compared to the Steinway which has a much stiffer frame, which is why the Yamaha has those two glide bolts to set the initial balance rail height. You are wise to inquire about the Estonia service manual, because that bedding procedure will likely save you a lot of time and head-scratching getting the regulation done properly.
Glide bolts are sometimes used to vary the key height other than removing/adding punchings on the balance rail. It's not a design flaw.
Good luck.
Sent: 02-13-2026 09:22
It means that the glide bolts were set high/deep to raise the balance rail, instead of just to establish contact with the key bed. This is a relatively new piano (I think <7 years) and hasn't seen any work since the dealer. Re-setting the glide bolts to standard approach lowered the keys/dip by about 2mm, and I'm finding it difficult to believe that the factory and/or dealer would choose a quick-fix method to establish key height on a $100k instrument. So that's why I'm wondering if it was designed to be over-bedded in a certain way. There's at least one other design thing I've never before seen.
Robin Whitehouse
Greenbelt, MD
D.C. Chapter 201
Sent: 02-11-2026 09:18
"Over-bedded"? What does that mean?
Stewart
Sent from my iPad
