  • 1.  Hammer bore geometry
    Posted 02-20-2026 22:25
    I am hanging new hammer assemblies on a 1987 Yamaha C5. After carefully measuring the string height and hammer center heights, calculating the bore, everything looks like it should work out fine. But - the hammer shanks are buried in the rest cushions at typical hammer blow. The original hammers were bored shorter and so the shanks were resting comfortably above the cushions (well, would have been if the action had been regulated recently). I believe that Yamaha spec is for zero degree rake. So why can't I get this to work out? It won't regulate properly if can't get the shanks off the cushions. Has anyone else encountered this problem?
    Dave Conte, RPT
    Piano Technician in Residence
    The University of Tennessee
    College of Music
    Knoxville TN
    (817) 307-5656
    Owner: Rocky Top Piano
  • 2.  RE: Hammer bore geometry
    Posted 02-21-2026 08:58
    I find Yamahas, you have to duplicate what was there. They had their reason, especially on a C5.
    If you changed the original bore distance, that's the problem.
    Dale Erwin mentioned problems like that on higher end Yamahas.
  • 3.  RE: Hammer bore geometry
    Posted 02-21-2026 10:16
    The Yamaha spec may not have been 0 degree rake. Have you already bored the hammers?
  • 4.  RE: Hammer bore geometry
    Posted 02-21-2026 13:04
    Dumb question:  Why did you not simply order new parts from Yamaha? (Repeat...dumb question 🤔)
  • 5.  RE: Hammer bore geometry
    Posted 02-21-2026 15:55
    Not a dumb question.
    I actually did, but this piano is an outlier with 23 bass notes.
    The set I received was 26. I now regret not just modifying three hammers.
    But I returned them and ordered set from Brooks with Ronson Wurzen AA
    felt as the client thought the piano should have a better tone.
    Dave Conte, RPT, CCT
    Owner, Rocky Top Piano
    Knoxville, TN
    817-307-5656
  • 6.  RE: Hammer bore geometry
    Posted 02-21-2026 20:06
    I'm not that familiar with Yamahawas, but it sounds like your working procedure for replacing hammers is a little flawed. Maybe when installing another set of hammers, you could set samples for proof of function first before committing to boring holes and gluing. Also keeping the originals for comparison along the way might help too.
    chrisppff@gmail.com
    Youtube@chernobieffpiano
