Hi Alan - I think any confusion is related to my unconventional friction measurement at the hammerhead. I only did that as a way to measure friction while installed on the hammer rail. The 5 - 10g friction was at the hammerhead (just as you describe) forward and backwards (yes, with the spring engaged - hence the difference in forward friction vs backward friction). The 1 - 2g friction was again at the hammerhead (with the hammerhead upwards like it is when mounted on the rail) while holding the flange in my finger. For sure, the actual numbers represent a somewhat meaningless friction measurement, but it does demonstrate the
difference in friction when the hammer assembly is mounted on the rail vs unmounted. I can measure the friction at the hammer both ways, but I can't measure the friction at the flange when it is screwed to the rail - only when it is unmounted.
Does that make sense?
Terry Farrell
Farrell Piano Service, Inc.
Brandon, Florida
terry@farrellpiano.com813-684-3505
Sent: 06-13-2022 13:24
Subject: Hammer Butt Flange Friction Mystery
Terry,
Please help me understand a couple of things.
When you say that you, "Check friction at hammer front and back and it is 5 to 10 grams when on rail," do you mean using a gram resistance gauge to push the hammer forward from the tail, and push it back from the hammer crown, presumably without the hammer return spring or bridle tape engaged? Might the acton be mounted on LaRoy's action cradle, and inverted such that the shanks are hanging vertically?
Also, did you ever figure out why, after you removed the parts from the rail, the resistance that was originally 3-5 grams had dropped to 1-2 grams? My apologies in advance if you already covered these points and I somehow missed it.
Alan Eder
Valencia CA
Sent: 06-12-2022 17:05
My measuring methods, I think, are reasonably described in my post. However, the problem as been solved. The problem only manifested itself in the treble section. The tenor and bass were nice and free. The flanges have some space between them in the tenor and bass. In the treble they are jammed snugly against one another. I removed a couple butts and inspected the pinning and bushings. Both protruded from the side of the wooden flange a small amount. I pushed the pins out a hair and cut is a tiny bit shorter and sliced off any protruding bushing. Reinstalled the trimmed assemblies and all if fine. Hammers move freely.
What a weird thing - I had just never seen that sort of a thing happen before! The center pins that stuck out a hair (and I mean a HAIR), were rubbing on their neighbors and creating excess friction!
Terry Farrell
Brandon, Florida
813-684-3505
Sent: 06-12-2022 16:17
Terry,
How are you measuring it in the piano?
