Good question.
You should take into account the status of your business and the attached possibilities of liability for the same. Take into consideration a worst-best case scenario and the potential insurance concerns should anything happen.
Most of us have small shops and that said, here are some very generic guidelines. Of course OSHA is the ultimate regulatory body for this type of thing however the old adage better safe than sorry" always holds true.
Yes I DO have proper fire safety storage containers both at the school/shop and at home.
LiquidsStorage Limits: You can store up to
25 gallons of Category 1 flammable liquids outside of a cabinet. For Categories 2–4, the limit increases to
120 gallons if stored in approved containers.
Approved Cabinets: If you exceed those limits, use
fire-rated cabinets labeled "Flammable – Keep Fire Away." Each cabinet can hold up to
60 gallons of Category 1–3 liquids.
Ventilation: Ensure good airflow to prevent vapor buildup, especially in enclosed areas.
Ignition Sources: Keep flammables away from heat, sparks, or open flames. Install
grounding and bonding systems if transferring liquids between containers.
Aerosols
Separate Storage: Do not store flammable aerosols in the same cabinet as flammable liquids. Aerosols require dedicated cages or lockers to prevent pressure-related hazards.
Temperature Control: Avoid high heat areas-metal cans with propellants like butane or propane can rupture under extreme temperatures.
Labeling: Make sure all aerosol containers are clearly marked and inventoried.
Other Chemicals
Safety Data Sheets (SDS): Keep SDSs for every chemical on-site and easily accessible. These guide your storage, handling, and emergency response protocols.
Compatibility: Store chemicals based on compatibility groups. For example, oxidizers should never be near flammables
Here's a link direct to OSHA standards on flammables
https://www.osha.gov/laws-regs/regulations/standardnumber/1910/1910.106
Hope this information is helpful. Best wishes in your choices and decisions on how to proceed.
Gerry
