Hi, Chris,
A little more research, perhaps.
Teflon is slick for some applications; and performs other functions for
others.
I use it a good deal in electronics work not because it restricts RF or
IF interference; but because it handles fairly high temperatures without
too much physical distortion (which would lead to mechanical failure of
protecting a soldered or non-soldered joint.
In those applications, I don't think of it as being slick.
In piano applications, in which teflon is usually seen as a finely
ground powder, it's a whole different thing.
While I basically agree with Ed, I'm sure there would be interest in
some reductive analysis of your proposition.
Kind regards.
Horace
On 12/12/2022 6:59 PM, Chris Chernobieff via Piano Technicians Guild wrote:
> Hmm..slicker than teflon??
> Original Message:
> Sent: 12/12/2022 9:20:00 PM
> From: Edward Foote
> Subject: RE: Heat Shrink Tubing
> To lower the coefficient of friction, and as another tool to fix a loose fit.
> Hmm, I don't think the heat shrink is going to be slicker than polished nickel plating,(or the WNG anodized), and if there is a loose fit, that would mean the felt has deteriorated. If I encountered an action with heat shrink on the pins, I would just shake my head at such a band-aid treatment.
> Original Message:
> Sent: 12/12/2022 8:24:00 PM
> From: Chris Chernobieff
> Original Message:
> Sent: 12/12/2022 7:20:00 PM
> From: James Kelly
> Why would you use heat shrink tubing on key pins ? Protection from rust & tarnish ?
> James Kelly
> Owner- Fur Elise Piano Service
> Pawleys Island SC
> (843) 325-4357
> Original Message:
> Sent: 12-12-2022 16:21
> Subject: Heat Shrink Tubing
> I just ordered some heat shrink tubing for use on Balance and front pins. Any tips or suggestions?
> Thanks in advance.
> -chris
> Chernobieff Piano Restorations
> "Where Tone is Key, and Mammoths are not extinct."
> 865-986-7720 (text only please)
> Reply to Sender :
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=758686&SenderKey=47cafae1-6d73-463c-a23c-1aec479e7538>
> Reply to Discussion :
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=758686>
> You are subscribed to "Pianotech" as
horace@horacegreeleypiano.com. To change your subscriptions, go to
http://my.ptg.org/preferences?section=Subscriptions. To unsubscribe from this community discussion, go to
http://my.ptg.org/HigherLogic/eGroups/Unsubscribe.aspx?UserKey=18d8c323-aa1d-4526-8bf1-a6805870cbe6&sKey=KeyRemoved&GroupKey=2bb4ebe8-4dba-4640-ae67-111903beaddf.>
Sent: 12/12/2022 9:59:00 PM
