You could replace them with used wooden sharps if you are lucky to find such with the mortices in the same location. The steam got under the finish. Several woodworking supply houses sell supplies to remove water rings. An antique restorer or good furniture e-finisher probably has the ability to fix it right quick.
maybe they will have to strip the keys and spray a new finish o
Sent: 07-13-2023 10:55
Subject: help with black key finish
Look for finishing products for removing white ring (glass) marks. Use jaras tool for removing key bushings and after removal immediately insert sizing caul.
Parker Leigh
Sent: 07-12-2023 23:20
Greetings all,
I steamed some front key bushings out, turned the set over, and got a nasty surprise: a whitish gook had formed on all the black keys.
I was able to get most off with steel wool, but now of course the keys don't look as black as the unharmed ones. Any suggestions on how to touch up the finish?
I do have some black TransTint, but I haven't yet used it.
thanks!
Scott Cole, RPT
rvpianotuner.com
Talent, OR
(541-601-9033
