I have used fish glue . You need to be careful with the glues you use for bushing work and in applying it . Too much and you get squeeze out and it saturates the felt and will harden it. I think the old brown glue may be best for other repairs. You do not need a lot of open time to do bushing work - just need to have the proper setup and technique.
Sent: 10-19-2022 07:43
Subject: Hot hide glue vs Old Brown Glue for key bushings
Benjamin,
OBG is the same as Titebond liquid hide glue. Just hide glue with urea.
This will be strong enough for key bushing but it may seep through the cloth more easily and require a longer cure time before you can remove the cauls.
