Joe,
There wouldn't be "extra" blow distance, there would be reduced blow distance. The "taller" the hammer (the longer the bore distance), the less blow distance there is given a uniform shank height at rest across the action.
I never really worried about blow distance, I concerned myself with let-off, key dip and aftertouch. Once I had these three elements where I wanted them, the resulting blow distance was whatever it was. I never measured blow distance. What the pianist feels is let-off, key dip, and aftertouch. Blow distance is merely something we technicians talk about.
David G. Hughes, RPT
David Hughes RPT
Vintage Case Parts
Glyndon MD
(443) 522-2201
Sent: 05-21-2024 13:28
Subject: How much should I add to the hammer bore distance to compensate for hammer prep?
So, David, I have a question. After you are done with all of your hammer prep, hammer to string mating, piano pounding (if you do that), and voicing, how much extra blow distance are you left with to compensate for future hammer wear?
Joe Burros
Cell: 646-410-7174
jbcello@gmail.com
www.fmi-newengland.com
Sent: 05-21-2024 07:04
Joe,
Golly, that's al lot of "So"s!
Now to the point, I always added 1.5mm, for several reasons, one being the matter you're concerned with.
Baltimore Chapter
David Hughes RPT
Vintage Case Parts
Glyndon MD
(443) 522-2201
