OK... Perhaps we should migrate or evolve this discussion into "How do you replace a string"?!
The technique I was taught might not be the absolute best, but it has worked for me for almost 50 years:
I unwind both tuning pins one full turn each, leaving the eyes about perpendicular to the strings.
Thread the new string through any agraffes and into the pin field, often I need to make a slight bend in the string to fit it through tight spaces which I try to do at about the normal location of the string bend (Becket?).
Using a free or spare tuning pin I insert the string into the eye and form exactly two careful and closely wrapped turns on the spare pin, then go 1/2 turn past this. NEVER let the free end of the string protrude from the tuning pin!
I pry the string off of my spare pin (with a screw driver) and place it on the correct original pin, using needle nose pliers I fit the bend into the eye, then I use my pliers to crimp the string a bit more tightly onto the pin.
I thread the string through the bridge pins, over the hitch pin and through the next set of bridge pins, then out over the capo bar to over the pin field. I cut the string using 4 fingers as my guide. To do this I look at the original stringing coils and I try to get the same number and angle of the bend as the originals by experience and how tightly I cut the string against my fingers (tight or loose).
Then I thread the string past the damper and either through the agraffe or under the capo bar. At this point it is often easier to handle the string if I remove it from the hitch pin to give myself more room to manuver. Using my spare tuning pin I put another 2 + turns on the string, pry off the string and manuver it onto the original tuning pin. I restore the string to the hitch pin and bridge pins if necessary.
Since I have the same two turns on both tuning pins I now bring the string carefully up to pitch and I attempt to create the same number of turns on both tuning pins.
I typically pinch the string at the hitch pin and gently seat the string at the bridge and all other bends, though in my old age I have begun to suspect that this might not always be best and allowing more natural settling of a string might be better for tone.
My father and grandfather were taught to unwind the tuning pin three turns and wind the turns onto the original tuning pin. I feel that this over-stresses the tuning pin in the block.
On a bass string or a single-tied treble string I usually measure and cut at a tight 4 fingers.
When stringing I do something similar, but tap in the new tuning pins with the new string.
Sent: 03-18-2023 09:58
Subject: How NOT to do a string repair
When I was prepping for my RTT test in the early eighties, I was asked if I would remove a tuning pin to make a new coil. Correct answer was to back the pin out just enough, not take it out.
I was asked because, apparently, pulling the pin was common practice with some.
David Stocker, RPT
