Greetings, Master Wing!
I had a client in Fayetteville, Arkansas with this exact problem. The tank was suspended directly BELOW one of the tension resonator bars, and horrible rust had occurred in the segment of the bar that was located directly above the water tank. I do not see how it would be possible to mount the tank above any of the bars. Please see attached photos for before and after pictures.
Dampp Chaser sells a bent hanger rod kit (part number 90180, it is intended for use in M&H pianos) that allows extra clearance to install the baffle below the tension resonator bar, in theory protecting it from excess moisture in that specific area. Last I was in contact with Dampp Chaser to order this part, they were unable to sell me the part directly as a customer, but instead allowed Pacific Piano to invoice me and then Dampp Chaser drop shipped the hanger rod kit to me. I installed the bent hanger rod Dampp Chaser kit on two M&H pianos.
To clean existing rust: M&H recommended grinding off as much rust as possible with a power sander, then hitting it with a clear coat of Rustoleum. I did just that, sanding down as much rust as I could, and spraying it with Rustoleum.
Limitations of this solution:
- I did not follow up on these instruments . I do not know if it was successful in completely eliminating the rust problem. I hope the baffle distributed the moisture around it and the problem did not return. If you would like, I could message the clients and let you know if any rust has occurred, even with the bent hanger rod configuration.
- I did not think it was possible to hang the tank in any other position. If it's possible that you can find a position for the tank that is not directly underneath the tension resonator bar, maybe you could try that and send pics.
Hope this was helpful!
Joshua Sadinsky
Santa Clarita CA
https://pianojosh.com/about------------------------------
Note : Recently uploaded media files are still processing:
