Thank you both Its one of those jobs you don't do frequently Last time I did it was on a spinet but this action has two flanges because of the ;long wooden sticker that sits above the keys. The bridal straps are not connected making it easier to work on the whippens.
Sent: 07-24-2023 15:04
Subject: Inserting and glueing Jack Springs
Like Paul said, a small flat screw driver is helpful to hold the spring down whilst removing the tweezers if they are catching.
Sent: 07-24-2023 12:13
I usually use tweezers. I'll place the spring into the hole with a little dab of glue, then grab a few coils near the top and direct the tip of the spring into the jack. It's a bit finicky, but it works. I make sure the bottom of the spring is fully seated, again using the tweezers. It's easier to do with the bridle straps disconnected so the wippen hangs down, using an action jig to hold everything.
