Admitting ignorance of the laser technology available for this purpose, so thoughts/comments are likely naive to irrelevant, but who's counting?
What are the outstanding advantages of laser levels in this application? Are they more accurate (for someone already experienced in the process)? I could definitely 'see' an advantage if they are linked to a sound indicator, which would eliminate the reliance on healthy visual acuity or good lighting... also a boon to posture. Could they be a useful aid for visually impaired technicians, the ranks of which I'm tending towards.
Problems emerge as per Chris's point: string-plane irregularity and how we accomodate that, depending upon the degree of control we have over the initial set-up. If we custom bored the hammers, that adjustment is built-in, and reflected in the hammer line (if all shanks are leveled). In fact, in such case, a laser-imposed hammer line could/would distort the original intent.
David Skolnik [RPT]
Hastings-on-Hudson NY
(917) 589-2625
Sent: 02-02-2026 22:03
Subject: laser level
Honestly, i think its more important that the hammer line follow the curvature of the plate, so hammer blow and everything else that follows is consistent.
chrisppff@gmail.com
Youtube@chernobieffpiano
