When all is said and done, by the time you remove your hammer (lever...whatever) from the tuning pin, the pin is "bent" like it or not. If it's not bent you do not have a stable situation. 150-230 lbs of tension produces a slight bend in the pin...period. the amount of bend depends on the diameter, coil height, and other characteristics, but a bend is a bend. The totality of forces involved is what must be left in a reasonably balanced condition (which clearly includes the forced "bend" in the tuning pin).
As we all know, this is the "trick"...balancing all these forces for stability. I don't care whether I bend (flex) the pin or not (in fact I always do). What I care about is settling everything into a situation that is stable afterward. The bend is my friend, and if I treat it right it remains my friend.
Sent: 10-18-2023 07:20
Subject: laser on a pin
The link and QR code to " Video and additional photos" return a "not found" error 404
Maybe someone in that chapter could locate the video ?
Sent: 10/17/2023 10:08:00 PM
Subject: RE: laser on a pin
The article mentions videos. Are there any?
Sent: 10-17-2023 21:56
I can see your point. It can flex the pin, but not if you hold the lever in a neutral position. I used to use a little bit of "English" to set the pin by lifting the lever to flex the pin forward and lock the pitch. I understand the theory of using handle of the lever below the plane of the string. The ideal would be if the tuning tip would only touch the pin at the bottom against the plate (like a spanner or box wrench). Then it could not flagpole the pin. Like I said, it did work well, but it was hard to carry in my tuning kit, and it ended up staying in the trunk. I sold it to someone with a shoulder problem, which was the reason I bought it in the first place.
Sent: 10-17-2023 18:09
Well, I have to disagree, Paul. It's certainly possible to bend the tuning pin side to side if you grasp the handle above the string plane but you don't have to do that and that is not where it is suggested that you grasp it. With a conventional lever, the pin can be bent in any direction (limited by proximity to the rim), depending on how you place it on the pin. The pin must bend when the handle is above the string plane and the laser experiment confirms that. The Levitan C lever can bend the pin away from or toward the string and also at angles, limited by the stretcher, but not by just turning it. I have been using the Levitan lever for 10 years now and I would never get rid of it.
Bob Anderson, RPT
Tucson, AZ
Sent: 10/17/2023 11:32:00 AM
No matter what kind of lever you use, you're going to bend (flex) the pin unless the lever is manipulated equally from both sides, like a T handle rotated around the pin. Or an impact-type of hammer. The C hammer is not immune from flexing the pin, but as the handle is generally in line with the string, the bending is side to side rather than fore-aft. Thus it doesn't affect the pitch much as you turn the pin. I used the C lever, but sold it to someone, so I have experience with it. It did work well.
Sent: 10-17-2023 11:20
Hi, Allan,
In one of the Dan Levitan class that I attended, he used a laser to demonstrate how a conventional tuning lever bends (or, if you prefer, "flexes") the tuning pin. He showed how it was possible to turn the tuning pin with his "C" lever WITHOUT flexing it. I've seen some fine tuners who haven't grasped that idea.
Bob Anderson, RPT
Tucson, AZ
Robert Anderson RPT
Tucson AZ
(520) 326-4048
