Ok. Here's a picture of the action with the mis-located let off buttons in place.
Making a new let off rail would be easy but I'm not sure how it would solve my problem.
Making a new action rail would probably open up a whole case full of cans of worms.
It's got a cove for the damper rod and mating surfaces for the flanges that would have
to be precisely duplicated. One of these days I hope to have the equipment to do that
sort of thing but I don't right now.
My current thinking is to take Jon's advice and get the correct size let off buttons. Drill out
both botched attempts at plugging and replug with a 1/2" dia. plugs (the ones I put in originally
were 1/4"). Then I will need to come up with some kind of shim to allow me to put the back
of the action rail on my drill press such that the front of the action rail would be exactly
perpendicular to the drill bit.
The nice thing about this piano is that it was a freebie. I do not have a client I will need to apologize
to. If things turn out really poorly I can take it to the junk yard and hope that the lessons I've learned
will translate into a better job next time.
Neil Vanderschaaf
Round Rock TX
Sent: 08-18-2022 16:09
Subject: Letoff rail problems
that plus fabricate a new rail with precisely located screws Pictures will help get you better suggestions.
Sent: 08-18-2022 12:40
Order the correct height for the Let Off Buttons. You should have done that from the start.
