Very interesting point you raise here, Steven! I was not aware of the engineering feature you mentioned in terms of the directionality of pin insertion.
This was the one removal and replacement of the lid in the life of this piano for which I was not personally present, due to extenuating circumstances. And the pins were in fact inserted with the L portion towards the tail on all three pins. You just might win the prize of a Reward In Heaven!
Sent: 11-08-2023 12:59
Subject: lid hinge pins stuck
Alan, if memory serves, the pin go in with the "L" facing the front of the piano. Was this the case on yours? Perhaps, if they went in from the rear, that end of the hinge is slightly closed and thus chewed up the pins.
Sent: 11-08-2023 08:17
Lists,
Thanks to all who responded to this thread!
Guess I'd lived a charmed existence up to this point, since I never needed anything heavier and harder than a modest rubber mallet to remove all the lid hinge pins I have had to remove over nearly fifty years. We tried steel hammers, but decided to cease and desist when we got to the three pounder and still none of the three lid hinge pins would budge.
Used a 1/8" nail set to get the pins moving just enough to make it possible to pull them the rest of the way out.
These are the original Yamaha pins, which featured opposing flat spots the long arm right before the 90o bend to the short one. All three pins had some "chewed" up surface just before the bend (inside the hinge). The roughness added about .008" to the diameter of the pins, which apparently was enough to keep the pins from being driven out, despite Big Bertha's best efforts (even in the hands of those younger and stringer than me). We sanded those rough areas down with emery cloth until they were closer to the .185" diameter of the body of the pin and were able to reinsert and readily remove them at will.
We are still flummoxed about what happened to this piano to cause the same game-changing roughness to all three pins in the same place. May never know the answer to that particular mystery, but at least we can declare, like the man said, "Mission Accomplished!"
Sent: 11-06-2023 10:35
I have driven out numerous stubborn hinge pins with a punch. Just need to watch that the hammer doesn't hit stuff its not supposed to smile 🙂
Sent: 11-05-2023 20:33
With the lid closed and the rim protected but a small vise grip on the hinge pin and use a dead blow hammer to hit the pliers . You can try doing the same with a drift . It is pretty difficult to unscrew hinges so you will need a number of people able to support the lid Sounds like the pins are bent or wrong size got banged in
Sent: 11-05-2023 19:27
You need to punch the pin with a drift and a steel hammer. If using pliers and a mallet won't work, you've pretty much run out of options. Last time I had this problem, I had to take some metal sanding paper and make the pin smaller before I could put it back in. Last ditch would be to unscrew the hinges and put in a vise. Good luck.
