And, to you, Sir!
Hmmm...perhaps a drive over to Quincy is in order.
In terms of proclivities, I prefer Bourbon....but, let's not get the
cart before the proverbial horse...first...we have to find 67mm pins.
Cheers!
Horace
On 8/23/2022 7:19 AM, Karl Roeder via Piano Technicians Guild wrote:
> Good morning Mr. Greeley,
> Fresh out of candy but you are near enough to my favorite distiller, Woodinville,?? in Quincy, WA , that should you locate a source for?? 67 mm pins I may have to have them send you a sample. Just don't know if you'd prefer their Rye or their Bourbon.
> Karl Roeder
> Pompano Beach FL
> Original Message:
> Sent: 08-22-2022 21:08
> From: Horace Greeley
> Subject: Long tuning pins
> Good Evening, Mr. Roeder,
> Hmmm....well...while it's been said (and said) that flattery will get
> you (almost) anywhere, I personally prefer Mr. Nash' version, to wit:
> "Candy is dandy; but,
> liquor is quicker"
> The relevance is rhetorical in that it appears to suggest that, should
> one run into some kind of resistance or problem when using one approach,
> perhaps it would be appropriate to return to one's tool box to see what
> one might have overlooked on a previous perambulation...perchance to
> fine a different "tool"...
> After over fifty-five years of working on pianos, I've discovered that
> this approach is often more beneficial that some, perhaps more lock-step
> one.
> OH, yes...the candy is for whomever. The liquor is, of course, for
> myself...almost always _after_ the onerous job is completed.
> Kind regards.
> Horace
> On 8/22/2022 5:01 PM, Karl Roeder via Piano Technicians Guild wrote:
>> Well, apart from my disappointment in not finding the pins, I must say that I'm stoked that I've got the same problem as Mr. Greeley. I really must be coming up in the world. I have to believe that Klinke still makes them. It may be that Steinway is their only customer for them and they've agreed not to sell them to anyone else.
>> Karl Roeder
>> Pompano Beach FL
>> Original Message:
>> Sent: 08-22-2022 12:37
>> From: Peter Grey
>> As I mentioned in the thread on coils, apparently 2 5/8" (67mm) tuning pins do not seem to be available anywhere these days.
>> Peter Grey Piano Doctor
>> Peter Grey
>> Stratham NH
>> (603) 686-2395
pianodoctor57@gmail.com <
pianodoctor57@gmail.com> <
pianodoctor57@gmail.com></
pianodoctor57@gmail.com>>
>> Original Message:
>> Sent: 08-21-2022 13:56
>> Good Morning!
>> I have the same problem on several semi-local D's here (Western WA).
>> Neither of PianoTek or Schaff carry these pins. I have an EM to Jahn,
>> in case they do.
>> What I have wound up doing, thus far, is what you've suggested, Karl. I
>> moved to 3/0 x 2-1/2" Diamond pins. While that's not choice one, they
>> are holding well on two D's that get multiple weekly tunings.
>> If anyone else knows of, or finds a source for the 2-5/8" pins, I would
>> love to know about it.
>> Thanks very much.
>> Kind regards.
>> Horace
>> On 8/21/2022 10:24 AM, Paul Williams via Piano Technicians Guild wrote:
>>> Try pianotek or Shaff
>>> Original Message:
>>> Sent: 8/21/2022 1:23:00 PM
>>> From: Karl Roeder
>>> Does anyone out there have a source for 2 5/8" (67mm) tuning pins? Steinway uses them on the model D but doesn't sell them any more. I've got to re-string a pair of D's in the next little while and will use 3/0 by 2 1/2"?? if I have to but would prefer to use the longer pins if I can find them.
>>> Karl Roeder
>>> Pompano Beach FL
>>> Reply to Sender :
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754637&SenderKey=53ca9fbf-b9a7-4b82-a4fe-c4c73bc1a762 <https: my.ptg.org/egroups/postreply/?groupid="43&MID=754637&SenderKey=53ca9fbf-b9a7-4b82-a4fe-c4c73bc1a762"> <https: my.ptg.org/egroups/postreply/?groupid="43&MID=754637&SenderKey=53ca9fbf-b9a7-4b82-a4fe-c4c73bc1a762">
>>> Reply to Discussion :
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754637 <https: my.ptg.org/egroups/postreply/?groupid="43&MID=754637"> <https: my.ptg.org/egroups/postreply/?groupid="43&MID=754637">
>>> You are subscribed to "Pianotech" as
horace@horacegreeleypiano.com <
horace@horacegreeleypiano.com> <
horace@horacegreeleypiano.com></
horace@horacegreeleypiano.com>>. To change your subscriptions, go to
http://my.ptg.org/preferences?section=Subscriptions. <http: my.ptg.org/preferences?section="Subscriptions."> <http: my.ptg.org/preferences?section="Subscriptions."> To unsubscribe from this community discussion, go to
http://my.ptg.org/HigherLogic/eGroups/Unsubscribe.aspx?UserKey=18d8c323-aa1d-4526-8bf1-a6805870cbe6&sKey=KeyRemoved&GroupKey=2bb4ebe8-4dba-4640-ae67-111903beaddf. <http: my.ptg.org/higherlogic/egroups/unsubscribe.aspx?userkey="18d8c323-aa1d-4526-8bf1-a6805870cbe6&sKey=KeyRemoved&GroupKey=2bb4ebe8-4dba-4640-ae67-111903beaddf."> <http: my.ptg.org/higherlogic/egroups/unsubscribe.aspx?userkey="18d8c323-aa1d-4526-8bf1-a6805870cbe6&sKey=KeyRemoved&GroupKey=2bb4ebe8-4dba-4640-ae67-111903beaddf.">
>> Original Message:
>> Sent: 8/21/2022 1:24:00 PM
>> From: Paul Williams
>> Subject: RE: Long tuning pins
>> Reply to Sender :
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754684&SenderKey=a488b50c-6a8f-40d9-99bd-d16f742b264b <https: my.ptg.org/egroups/postreply/?groupid="43&MID=754684&SenderKey=a488b50c-6a8f-40d9-99bd-d16f742b264b">
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754684 <https: my.ptg.org/egroups/postreply/?groupid="43&MID=754684">
horace@horacegreeleypiano.com>. To change your subscriptions, go to
http://my.ptg.org/preferences?section=Subscriptions. <http: my.ptg.org/preferences?section="Subscriptions."> To unsubscribe from this community discussion, go to
> Original Message:
> Sent: 8/22/2022 8:02:00 PM
> From: Karl Roeder
> Karl Roeder
> Pompano Beach FL
> Original Message:
> From: Peter Grey
> Peter Grey
> Stratham NH
> (603) 686-2395
> Original Message:
> Good Morning!
> in case they do.
> Thanks very much.
> Kind regards.
> Horace
>> Original Message:
>> From: Karl Roeder
>> Karl Roeder
>> Pompano Beach FL
>> Reply to Sender :
> Original Message:
> From: Paul Williams
> </http:></http:></
horace@horacegreeleypiano.com>></
horace@horacegreeleypiano.com></https:></https:></
> Reply to Sender :
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754700&SenderKey=a488b50c-6a8f-40d9-99bd-d16f742b264b>
https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754700>
horace@horacegreeleypiano.com. To change your subscriptions, go to
http://my.ptg.org/preferences?section=Subscriptions. To unsubscribe from this community discussion, go to
http://my.ptg.org/HigherLogic/eGroups/Unsubscribe.aspx?UserKey=18d8c323-aa1d-4526-8bf1-a6805870cbe6&sKey=KeyRemoved&GroupKey=2bb4ebe8-4dba-4640-ae67-111903beaddf.>
Sent: 8/23/2022 10:19:00 AM
Fresh out of candy but you are near enough to my favorite distiller, Woodinville, in Quincy, WA , that should you locate a source for 67 mm pins I may have to have them send you a sample. Just don't know if you'd prefer their Rye or their Bourbon.
liquor is quicker"
one.
Kind regards.
Horace
> Karl Roeder
> Pompano Beach FL
> Original Message:
> From: Peter Grey
> Peter Grey
> Stratham NH
> (603) 686-2395
> pianodoctor57@gmail.com <pianodoctor57@gmail.com>
> Original Message:
> Good Morning!
> in case they do.
> Thanks very much.
> Kind regards.
> Horace
>> Original Message:
>> From: Karl Roeder
>> Karl Roeder
>> Pompano Beach FL
>> Reply to Sender : https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754637&SenderKey=53ca9fbf-b9a7-4b82-a4fe-c4c73bc1a762 <https: my.ptg.org/egroups/postreply/?groupid="43&MID=754637&SenderKey=53ca9fbf-b9a7-4b82-a4fe-c4c73bc1a762">
>> Reply to Discussion : https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754637 <https: my.ptg.org/egroups/postreply/?groupid="43&MID=754637">
>> You are subscribed to "Pianotech" as horace@horacegreeleypiano.com <horace@horacegreeleypiano.com>. To change your subscriptions, go to http://my.ptg.org/preferences?section=Subscriptions. <http: my.ptg.org/preferences?section="Subscriptions."> To unsubscribe from this community discussion, go to http://my.ptg.org/HigherLogic/eGroups/Unsubscribe.aspx?UserKey=18d8c323-aa1d-4526-8bf1-a6805870cbe6&sKey=KeyRemoved&GroupKey=2bb4ebe8-4dba-4640-ae67-111903beaddf. <http: my.ptg.org/higherlogic/egroups/unsubscribe.aspx?userkey="18d8c323-aa1d-4526-8bf1-a6805870cbe6&sKey=KeyRemoved&GroupKey=2bb4ebe8-4dba-4640-ae67-111903beaddf.">
> Original Message:
> From: Paul Williams
> Reply to Sender : https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754684&SenderKey=a488b50c-6a8f-40d9-99bd-d16f742b264b
> Reply to Discussion : https://my.ptg.org/eGroups/PostReply/?GroupId=43&MID=754684
> You are subscribed to "Pianotech" as horace@horacegreeleypiano.com. To change your subscriptions, go to http://my.ptg.org/preferences?section=Subscriptions. To unsubscribe from this community discussion, go to http://my.ptg.org/HigherLogic/eGroups/Unsubscribe.aspx?UserKey=18d8c323-aa1d-4526-8bf1-a6805870cbe6&sKey=KeyRemoved&GroupKey=2bb4ebe8-4dba-4640-ae67-111903beaddf.
Good Morning!
in case they do.
Thanks very much.
Kind regards.
Horace
> Original Message:
> From: Karl Roeder
> Karl Roeder
> Pompano Beach FL
