The post (only 1) is loose and wobbling, indicating the glue joint failed. I don't believe I have encountered the tenons being doweled in addition to the wooden wedges inserted in Steinway lyres. I was hoping someone might have some info that would enlighten my understanding of the construction. I can always ask the manufacturer, or course.
I find it curious that only the top tenons are bound horizontally as well as wedged. My assumption is that the top block is not visible, whereas the pedal box is, and becomes harder to mask cosmetically a dowel hole (although on the less visible tail side.)
The pedal box tenons do seem more vulnerable than those in the top block, with the extra pressure exerted nearby from the pedals. Add movers using the lyre to support the weight of the piano, and even a relatively newish lyre can start elongating with pedal playing. This piano is fairly heavily used, in a music school, and has been moved multiple times.
Sent: 12/25/2025 1:52:00 PM
Subject: RE: Lyre posts construction
I was thinking similarly but did not want to ask, assuming that I knew. 🤔
Sent: 12-25-2025 10:58
Subject: Lyre posts construction
Missing information. For what purpose does the singular post need to be removed?
