Thank you Matt, and thank you David.
I am impressed that a machinist made duplicate agraffes.
As you may be aware, Schaff now sells the retrofit tools and materials to drill out the plate, tap, install sleeves, and then install standard 1/4" dia. agraffes. Pianotek had this system for sale and there is a short video on the process available as well. I think that I will go this route because then if an agraffe ever needs replacing, a new agraffe will be more likely available.
Thanks again for the replies. I extremely grateful for this technical resource we have within the PTG.
Sincerely,
Tom Wright, RPT
Sent: 04-04-2024 09:33
Subject: Mason Hamlin vintage agraffes replacement
Hi Tom, sorry for the late reply here, I get a little swamped with work during the week. I'm happy to share with you the manufacturer of my Agraffes.
EDWARD KOEHN CO., INC.Office: 510-843-0821 x 1Cell: 510-316-1392www.ekmfg.com
I went with them because they were across the street from our place. To tell the truth, they were just a little slow on the project because I only ordered a hundred. They usually do much bigger projects. I'm guessing this was a neighborly courtesy. With that said, if you need the same size agraffes as what I ordered from them, I bet you they already have the specs on file for reproduction. I actually gave them one of the originals and they reproduced it. Do you have any pictures of your agraffes. The piano I did was a vintage screw stringer. The agraffes were a different thread count and size than the usual 9/32" agraffes that you find on Mason and Hamlin pianos.
Matt
Sent: 4/2/2024 2:15:00 PM
Subject: RE: Mason Hamlin vintage agraffes replacement
Greetings Matt,
I'm in Maryland and I'm working on a vintage Mason & Hamlin for a church here. Would you be willing to relay information on the CNC machinist rework for the agraffes? I'd gladly work with the same business if they would like to consider doing this again.
I'm thinking this would be to machine a larger metric agraffe down to the unusual diameter and thread pitch of these old agraffes, would this be correct?
Thanks so much. This issue left me wondering how was going to be able to provide new agraffes for this project since I had never encountered it before.
Sincerely,
Tom Wright, RPT
Sent: 07-13-2023 03:42
Hi all, I just had a similar issue with a MH screw stringer. I had the agraffes remade by a cnc machinist, not too expensive and worked out great. I haven't heard of replacing with a metric size, but that may be the quick fix option. Best. Matt
-Matt Crudo, RPT
