Robert,
If it does not look like a simple fix, and it was purchased on line, I would suggest returning it as defective.
That said, I altered one fellow's adjustable bench (that was irreparable wobbly) into a non-adjustable form at the height he liked by cutting identical shims (blocks) attached between the lower frame and the seat frame. Now very solid.
If it's a cheap bench...well it's cheap. If not, as Pat said, there's help a phone call away.
Sent: 09-09-2025 13:31
Subject: Piano bench seat not level
Hi Robert,
Which brand/model adjustable bench are you dealing with? If it's Jansen, you might try calling them. If they aren't sufficiently helpful, there are a number of folks familiar with maintaining the mechanisms here (or in the CAUT forum).
Good luck!
