Thanks to all for the good responses. Very lively. The consensus to my question was obviously that there is no need to inform our customers of any potential health hazards associated with using piano-specific evaporative-type humidifying systems. I'm afraid that I personally need a scientific study which says "forget it, it is not a problem," before I consider taking the potential health issue off my list of considerations and before I stop mentioning it to my customers concerned about the best way to achieve good humidity control.
And yes, California Proposition 65 is it? We all know where some comments are coming from! I'll post a couple responses below that might be of assistance relative to the comments that we got.
1) Thanks for the update on how piano humidifying systems include some surge protection; I need to look into it. For electrocution protection, I am used to appliances needing a three-wire system/plug. Such as with the ALCI plugs (like a GFCI on the supply side) that come with hair dryers.
2) Chemicals sitting in water, like with those used in cleaning toilet bowls, I don't believe would be the equivalent to piano humidifying systems actively putting minute quantities of toxic chemicals in the air, due to there not being a heater along with pads or a wick.
3) True, my wife and I are up to date on our Covid-19 boosters – in fact, we just got the latest one yesterday. But I think such is OK to do if we are up to speed on both the pros and cons -- and then decide to go for it. Others decide not to.
4) I did not realize that there are multiple types of room humidifiers: ultrasonic, vaporizing, evaporative-vaporizing, and whatever else. In a small sample that I looked at on Amazon, none had pads and none referred to adding chemicals to the water reservoir – but I presume that there are some that do so. All the units that I looked into require weekly, or frequent, cleaning for bacteria or for other reasons. The only whole-home humidifying systems that I am familiar with use flowing water near the central air-flow furnace, so no chemicals for anti-bacteria purposes are required.
5) Lastly, this topic of potential health considerations can get complex. If anyone wants to pursue it further, I suggest the use of a good AI engine. You can contact me direct about it.
Regards, Norman.
potomacpiano@verizon.nethttps://potomacpiano.com(301) 983.9321
Sent: 09-27-2023 01:08
Subject: Piano Humidifying Systems – Is There A Health Consideration?
Norman,
In California there would probably be a required warning label on a DampChaser system, but then we have warning labels on cars (please note, in spite of my sarcastic cynicsm about this subject I do not recommend that you or anyone around you eat a car or any of its components)!
