" a new powersupply with two separate components plus the correct cables fixed the power issues". Well this is music to my ears ;)
Where can I see a picture of this system please? A link, model, picture or something would help me figure out if I can use it as a retrofit.
Before the powersupply broke, I was using a yamaha dongle for blutooth, streaming to my piano. It was working like a champ too. Radio stations and all with symphony.
Joey Liender
Sent: 08-31-2023 19:29
Subject: PianoDisk 8th generation PowerSupply problem
there are a number of technicians that do a significant amount of piano disc work but I am not sure if any rebuild the power supplies. Piano disc was buying back old PD equipment but I am not sure why unless they where thinking of refurbishing equipment. The new wireless Prodigy systems are great but they are not cheap . I have installed several and it is time intensive as well as challenging. I had a customer who thought he could do a wireless setup because he had an ipod interface. Eventually he called me but only after blowing the power supply which he claimed had a power surge hit it . A new power supply with two separate components plus the correct cables fixed the power issues. In addition an airport express made the unit totally wireless. You could try Piano Disc on the West Coast tech support for schematics. Also post something on the player piano community thread
Sent: 08-31-2023 17:44
Great to hear from you James and thank you. Yes I have been hoping a power surge being the cause too given that I can't really identify any real culprit components. Based on that, I did go ahead and ordered a bunch of BussMann 250V, 4A MLD glass fuses. It my best guess. Please let me know if that passes your giggle test. So I will replace one and see if we can be that lucky.
I hear what you are saying about finding a schematic. But frankly, a newer schematics would be more helpful to me right now than no schematics. Any advice on how to get something reasonable please?
thank you much
Joey
Joey Liender
Sent: 08-31-2023 16:26
There may have been a power surge that took out fuse 2. Maybe try replacing that fuse and see if you can get 40v to power the solenoids. The newer power supplies have two transformers instead of the large heavy auto battery size dual supply. There are also different cables. The PDS 128 is a very old first generation system I think it will be next to impossible to get schematics
