Once again I am grateful for the comments.
There are several reasons I've had for posting this question. My first and most important being that I was wondering if this behavior was a warning, a canary in the mineshaft so to speak, of something more serious to develop. This doesn't seem to be the case.
As far as my client goes, Scott, no she had never noticed it and won't worry about it unless I come back with some dire prediction of impending doom.
The last reason is that, as a trained engineer, I find the puzzle as to why it is happening intriguing. I have tried to create a list of some of the possibilities:
- The metallurgy of the strings used.
- The use of the AccuTuner to monitor the pitch variation.
- A reaction of the tuning pins, agraffs, capo bar, bridge or hitch pins to the wild excursions of the string.
- A change in the atmospheric composition such as a higher concentration of Helium when the note being played is loud. OK, I'm not really taking this possibility seriously, but it does sound like it could be an interesting experiment to run.
So one of the good things that came out of this is that I had never taken the time to map out which partials the AccuTuner listens to. For the setup I was using, it turns out it doesn't start using the 1st partial (fundamental) until C6. I can't remember if I was worrying about this in that range of the piano or not. Something I'll keep in mind the next time I have a chance visit the piano.
I also plan to go back and study in
Once again, thanks and if this has triggered any memories or experiences I'd love to hear about them further.
Neil Vanderschaaf
Round Rock TX
Sent: 08-04-2023 01:48
Subject: Pitch droop as the sound volume decreases
Neil,
The Yamaha GA1 was a transition model from about 2001 to 2005 and was replaced by the GB1 which corrected some string scaling issues. The GA1 lowest 6 plain wire notes (27-32) are way under tensioned (90lbs per string up to 124 lbs per string) and I am wondering if the pitch drop was more pronounced in this area. Let me know if this is the case.
As for restringing you might want to look at one of my web pages: http://www.goptools.com/bassretro/ where I converted the lowest 6 plain wire notes to bichord bass notes. This corrected the tension problems and also improved overall stability. There is also a white paper there that I wrote concerning the conversion.
Tremaine Parsons RPT
Georgetown CA
(530) 333-9299
