Turpentine should work.
In California we have lost many of our solvents like paint thinner and naptha due to its polluting qualities.
But we can still buy charcoal starter, which is similar enough to paint thinner and I have been using that as a useful solvent.
Alcohol might work, but the risk to a shellac finish is too great, paint thinner or "charcoal starter" is probably safer (though smellier).
You could also try just another application of Pledge as it might dissolve enough of the old residue to work as a cleaner.
WD-40 might work too, or Goof-Off.
You also might want to just try a simple cleaning agent (I use Spic n Span) and some elbow grease.
