Hi Mary,
Installing a string in the understrung section is always a pain. The good news is that you have a bass string to deal with, so at least the treble wire won't be bouncing around while you're trying to feed it to the right position.
The first time I did this, I got a thin PVC pipe. I fed the new string through that. It definitely helped, however, I lost the PVC pipe sometime after that and haven't replaced it since. Especially when dealing with a bass string, it's easy enough to get it to about the right position using an extendable magnet and tweezers.
I'm sorry there's not really a silver bullet for this. Replacing a string here is a little more hassle than replacing it elsewhere, but it's not too terrible most of the time. You'll definitely get an exercise in patience as part of the experience.
www.professional-piano-services.comwww.FromZeroToSixFiguresBook.com------------------------------
