Sent: 11-02-2023 14:53
Subject: readily reversible adhesive for WNG heel-to-wippen glue-up
Sent: 11/2/2023 12:23:00 PM
Subject: RE: readily reversible adhesive for WNG heel-to-wippen glue-up
Alan,
What did you end up doing with this?
Sent: 10-24-2023 10:30
I glued some knuckles to WNG shanks with Pianotek's PVC-E to try out the position, meaning to go back and use CA on them later. The bond was so strong I left them alone. It's been 5 years or so with no problem.
John Pope
Lexington, KY
Sent: 10-21-2023 18:53
If Roo glue is working, there's a conservation adhesive I use on keytops called Jade R that is similar to a PVA glue (PVC-E, Aileen's, Titebond Melamine, etc.). It is fully reversible with water. I thought the PVA family of glues would be too rubbery. Jade R is just a little thinner than PVC-E, but is still very tacky and handles very similarly.
Mathias Walters
North Charleston SC
(843) 619-7593
Sent: 10-21-2023 18:48
Hi Alan,
We have a similar situation in our shop when we redesign an action for new keys and action parts (or whole stacks). We have to make an educated guess at the magic line and heel height before the build so we can set things up and make sure it all works. We only use two wippens on notes 1 and 88. We glue up the heels with Roo glue (Pianotek / Schaff). I was surprised that it's quite a strong bond, not as strong as CA Gel glue, but strong enough since there's almost no stress on that joint. At the end of the process we may change the heels a mm or two.
In any case, Roo glue releases with heat quite nicely. We do find cleaning the Roo glue out is a time consuming chore though, so the 2nd set you may want to stick with Roo glue if it works reliably. I don't know if it would work to reglue later with CA glue mixed with Roo glue.
-Dean
Dean Reyburn, RPT
Reyburn Pianoworks
Reyburn CyberTuner
1-616-498-9854
dean@reyburn.com
www.reyburnpianoworks.com
www.cybertuner.com
www.reyburntools.com
Facebook: www.facebook.com/dean.reyburn
