I like your ingenuity. I'm probably going to go with the twin upright dollies from Schaff: no fuss, no muss installation.
I had imagined that I could use the HD 2" double wheel casters in the back, in the existing 7/8" deep 2-3/8 dia. holes for the originals that IF I ALSO could find hard rubber casters the same as the originals in the toe blocks (20mm.), the pedals would only be lifted 1/4". But for a 20mm. dia. wheel, the load rating drops greatly when going from brass/iron to rubber. Also this arrangement produces a 4º slant toward the front (the direction which helps the forward lean of the piano's back). And I wasn't sure whether the stems would need a backwards 4º tilt to keep the stems vertical, or whether the a 4º tilt of normal would even get in the way of the wheels aligning themselves for traveling.
I also toyed with the idea of attached a 2" square of 3/4" plywood to the bottom board, that the pianist could place their heels. This would raide along with the piano, but on the floor (with a layer of something to be the actual contact surface with the floor).
In the end, I figured that if the above twin dollies' 3/4" pedal lift was wrong for pianists, they would have been redesigned. 3/4" must be tolerable.
Sent: 06-04-2023 10:41
Subject: Real Casters for a Yamaha T118 Vertical
I had the problem of too high pedals on an upright I put casters on. There was no way to recess the wheels. The pedals were about 3+ inches above the floor
The Schimmel came with no wheels. It was a 1950's and had a continuous rim plate.
I saw the pedals were brass or I had a set of brass ones that were similar. I forget. I cut the front off the pedals and brazed it back together at a lower height. I gained 1 1/2".
I was amazed that the brazing rod was the same color as the pedal and when I ground it smooth, you couldn't see the joint.
They looked like it came from the factory that way.
Purely accidental but when it happens that way on your first try and they work perfectly, you wonder if that will ever happen again,,
Sent: 6/3/2023 9:16:00 PM
Subject: RE: Real Casters for a Yamaha T118 Vertical
I could ask Yamaha. However if your casters didn't change the pedal height (and if you didn't have to sink them deeper into the wooden frame), then they must have been the same size. I think it's really worthwhile to go from the ~20mm originals up to the standard for non-living room pianos - 2" dia. hard rubber, double-wheel, double-race ball-bearing casters.
I'm planning on mounting the new casters up higher in the frame, so as to enjoy the larger dia. wheels AND not change the pedal height.
Sent: 06-03-2023 18:49
Bill
Many years ago I replaced the brass castors on a Yamaha U1. I got replacement casters from Yamaha, so replacement didn't affect pedal height and the replacements didn't require any case modifications. Maybe Yamaha doesn't supply the rubber double-wheel type caster for all models.
Just thought I'd ask, if you checked with Yamaha for their caster rather than trying to make a Schaff caster work.
Richard West
Sent: 6/3/2023 6:25:00 PM
Hardwood. It's a community that used to be a laundromat. Nicely redone, too.
Sent: 06-03-2023 17:23
Carpet or hard wood floor?
